Need some advice?
brunutt
Need some advice?
Post by brunutt »
I bought several SS saw blades off ebay and they came with Model 500 arbors. I have a Model 510 is it possible to use the 500 arbors on the 510?
billmayo
500 Arbor use on a 510
Post by billmayo »
It is possible but not recommended as you would have to extend the quill and you cannot use the 510 lower and upper saw guards. Without the saw guards, it would be very dangerous for you or anyone in the shop. I would buy the 510 arbors as this is must cheaper than a mangled/lost finger or hand plus all the saw dust floating in the air in your shop.
brunutt wrote:I bought several SS saw blades off ebay and they came with Model 500 arbors. I have a Model 510 is it possible to use the 500 arbors on the 510?
a1gutterman
Post by a1gutterman »
Too bad...
Model 505, 510 and 520 Saw Blade Arbors!
Get one for every blade so you can change from blade to blade almost instantly. 1-1/4” Saw Blade Arbor OR 5/8” Saw Arbor Regularly $23.99 Now Only $15.59 You Save $8.40
...this sale was up on June 19. :( But you can still get 20% off the current price of $23.99 if you order them by June 30th!:)
Tim
