Parts
Parts
Picked these up today from a person who listed these on CL. It had 4 bandsaw blades still in the box NOS, drill bit starter set NOS, drill chuck, 5 router bits NOS, router chuck NOS, 4 Stern Forster bits, 3 table saw blades, safety push items, sanding disk and pads, 5/8 universal arbor NOS, screw center, tailstock chuck arbor, lathe tool rest and assembly, small lathe plate, lathe drive center, and lathe cup center. Not bad for a Benjamin IMHO.
- parts
- IMG_0436.PNG (685.55 KiB) Viewed 7244 times
- everettdavis
Re: Parts
It looks like you also scored a Briggs & Stratton Flywheel Holder used to secure it when removing starter pull clutch assembly. Worth $25 by itself.
That can be sold on eBay pretty easily for $20 or so.
Everett
Everett
- everettdavis
Re: Parts
On closer look, the item in the lower left side of your photo in the zip-lock bag appears to the Starter Clutch removal tool (used with a ratchet or break-over bar) opposed to the one piece tool shown in the illustration, which adds to the value of your score.
Everett
Everett
