No oiling holes?
No oiling holes?
I bought the zoom spout oiler for the sole purpose of lubricating the bearings on the floating sheaves, but there are no holes in either sheave’s sleeves. According to the serial number, this ShopSmith was made in October 1955. Do these bearings not require lubrication? Here is what it says in the owner’s manual:
BEARINGS – All spindle bearings are grease sealed and require no lubrication for the life of the machine.
I also could not remove the quill to wax/lubricate it. Is the quill in this machine not designed to be removed?
Again, here is what it says in the owner’s manual:
QUILL – Lock quill in maximum extended position. Apply light coat of grease (Magna Lube) to rack teeth. Place a few drops of oil on top surface of quill and run quill in and out several time to spread the oil.
Sincerely,
Ron
Sincerely,
Ron
No oiling holes?
Yes, The sheaves do need lubication. They are not bearings as they only slide on a shaft, not rotate on the shaft. The drive sleeve and idler shaft has sealed bearings that do not need lubication.
I find the Greenies I rebuild do not have an oil hole in the control or floating sheaves. I drill a 5/32" hole on the keyway 3/16" from the raised collar on both sheaves. Since I cannot get to the control sheave to oil it, I drill a 3" hole (metal hole saw) centered between the holes that hold the LOGO cover. I have a jig I made for centering the hole. I then use a 3/4" wide flat aluminum bracket the length of the LOGO diameter with a hole drilled at the top and bottom of the LOGO cover and matching holes in the bracket. I use 2 #8 sheet metal screws to hold the logo cover to the bracket. This allows me to oil the control sheave and blow sawdust from the headstock during maintenance checkups.
All quill housings can be removed. There is a set screw about 1" in on top the may have filler in it so you cannot see it at first glance. Dig the filler out with a small prick or screwdriver and loose the 5/32" set screw. Keep a tight grip on the quill advance handle as you remove the quill housing and let it slowly unwind. When installing you need to go 2 1/2-3 turns CW before installing the quill housing. If you do remove the quill housing, I use plenty of good wheel bearing grease on the end of the splined end of the shaft to get lubication into the drive sleeve housing. If you are not having any problems with extending or retracting the quill, play in the shaft or loud noise from the top of the housing, what you did should for the quill housing will be good until the next time for lubication.
Ron309753 wrote:I bought the zoom spout oiler for the sole purpose of lubricating the bearings on the floating sheaves, but there are no holes in either sheave’s sleeves. According to the serial number, this ShopSmith was made in October 1955. Do these bearings not require lubrication? Here is what it says in the owner’s manual:
Sincerely,
Ron
Bill,
Thanks! Great info as usual. I’ve been studying the drawings in the back of the owner’s manual and I think I understand now about the sheaves and the bearings. These may sound like dumb questions, but I assume that before you drill them, you must remove the floating sheave from the motor shaft and the control sheave from the idler shaft? For that to happen it looks like you would have to remove the spring, spring case, and the retaining ring from the motor shaft. If so, what do you use to compress the spring so you can get the ring off, and then back on again?
My greenie has an access hole under the logo cover.
I also figured out what the issue was with the quill. There was so much sawdust compacted in the gear that the last few teeth on the quill would not engage. When I cleaned that out I was able to remove the quill.
Ron
Ron
No oiling holes?
If you haven't already done so, you might want to watch Sawdust Session #22, "SS Reborn #2". I've watched this three times already. Now all I need is a headstock to tear down. Shopsmith better lay in some parts for the surge of rebuilds.
In this one, Nick gets down to the point you will have to go to drill your holes.
http://www.shopsmithacademy.com/SS_Archives/SS122/SS122_Common_files/Blackboard_images/Inspection_and_Cleaning.pdf
http://www.shopsmithacademy.com/SS_Archives/SS122/SS122_Shopsmith_Reborn_Pt2.htm
Zoom Oiler - extends 14" from hand.
Finally, found a Zoom Oiler, that started this post. It has a 14" extension oiling tube. The one pictured is available on AMAZON. The one that I found, is the same container w/Turbine oil. Turbine oil: Paraffin base, non-gumming, rust & oxidation inhibited, withstands high temperaures. This one was at a ACE Hardeware in Gig Harbor, WA.
[ATTACH]2455[/ATTACH]
- Turbine oiler.jpg (14.79 KiB) Viewed 7308 times
- zoom spout.jpg (16.9 KiB) Viewed 7804 times
MK V 520; MK V 510 w/PP DIY Upgrade; MK 5 500; Jointer; Bandsaw; Sliding Table; Conical Sanding Disk; Sharpening Guide, Lathe Duplicator, Jigsaw, Scrollsaw, Beltsander, Ring Master, Biscuit Joiner.
- terrydowning
Photos of this would be very helpful. Do any exist?billmayo wrote: I find the Greenies I rebuild do not have an oil hole in the control or floating sheaves. I drill a 5/32" hole on the keyway 3/16" from the raised collar on both sheaves. Since I cannot get to the control sheave to oil it, I drill a 3" hole (metal hole saw) centered between the holes that hold the LOGO cover. I have a jig I made for centering the hole. I then use a 3/4" wide flat aluminum bracket the length of the LOGO diameter with a hole drilled at the top and bottom of the LOGO cover and matching holes in the bracket. I use 2 #8 sheet metal screws to hold the logo cover to the bracket. This allows me to oil the control sheave and blow sawdust from the headstock during maintenance checkups.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
Terry
Check the links in post #4. Moving pix no less!:)terrydowning wrote:Photos of this would be very helpful. Do any exist?
- terrydowning
JPG40504 wrote:Check the links in post #4. Moving pix no less!:)
Being able to print the photo/diagram of exactly where to drill the holes and take out to the shop would still be helpful.
Terry
Terry
- RobertTaylor
there really is no exact place to drill the holes. anywhere on either of the sheaves will work. the idea is to get oil on the shaft so that the sheave will move easily. in fact you don't need to drill holes at all if you like to do extra work every time you want to do maintenance. also if you don't want to make your machine last indefinately don't oil the sheaves at all. when you order new parts they will be drilled already from the factory.
