A suit over 4X4's when will it end
Check this out from FineHomebuilding.
http://www.finehomebuilding.com/2017/06 ... =166441699
If the judge doesn't throw it out on the first day (probably won't) and it goes to a jury trial the idiot jury will probably find in favor of the plaintiffs. No wonder the justice system is screwed up. Lawyers are not interested in justice only money. It is really sad.
Hobbyman2
Re: A suit over 4X4's when will it end
Post by Hobbyman2 »
The average person will care less one way or another,.
This reminds me of a conversation I had with a college professor years ago in robotics class about building materials , all their formulas dealing with construction material were based on fictional numbers,, a 2x4 isnt a 2x4 so the strength in the formulas were all wrong,, all though he agreed with me he still insisted on the math be done in a fictional form because it was the status quo .
And folks complain when a concrete mix isnt correct.
for the average deck or porch a 3.5 x 3.5 will work as well as a 4x4 in most locations , they should just label the lumber and offer correct size lumber for those who care.
The 2x4 in the old part of the house measures 1 7/8 x 3 7/8
It sucks when a are trying to match up a floor or wall repair with the new stuff.
As far as the board strength of the two they dont compare .
Hobbyman2
Post by Hobbyman2 »
when is a 4x4 a 4x4
When it isnt a 10 gllon hat.
Hobbyman2 wrote:https://courses.cit.cornell.edu/arch264 ... xample7.1/
Capacity of wood column calculator
Jonathan Ochshorn
© 2008-2014 Jonathan Ochshorn.
contact | academic homepage | Structural Elements text | calculator homepage
Directions: Select wood species and grade (or enter values for modulus of elasticity, E, and allowable stress, Fc, after setting "Species" for "Other"), wet service conditions, duration of load factor (CD), and effective column height for both axes (unless braced at different points, both heights should be the same -- see Fig. 1). Select either the 2005 or 2012 National Design Specification (NDS) values for lumber sizes, and choose either nails or bolts for built-up columns (see the NDS for nail and bolt requirements). Revised values for Southern Pine (effective June 1, 2013) are included only when the 2012 NDS is selected. Press "update" button.
See additional explanations and examples in my text. The duration of load factor, CD, for common proportions of dead and live loads is 1.0. For other combined loads (e.g., snow and dead load), see text for further details.
Note that the size factor adjustment (CF) should not be included in the allowable stress value entered, as it is already included in the calculations for each column size. The combined values of allowable stress and size factor for Southern Pine have been accounted for.
The x-axis refers to the "strong" axis of bending, except in the case of 3-2x4's bolted together, where the y-axis is stronger (see Fig. 2a). Fig. 2b shows an example where different unbraced lengths apply to the two axes: sheathing nailed to the stud prevents buckling about the y-axis, but not the x-axis. In this case, one might model the column with an unbraced height of 8 feet about the x-axis, and 0 feet about the y-axis.
axes of buckling
Fig. 1. Wood compression element showing different unbraced lengths for x- and y-axesaxes of buckling
Fig. 2. a) definition of x- and y-axes for wood cross-sections; b) example of continuous bracing for y-axis
Update
Species
These values not used except for 'other' species
Dimension lumber
Fc (psi) =
1,700
Emin (psi) =
690,000
Emin (psi) Fc (psi) Column size Capacity (lb)
580,000
1100
2x4
636
2-2x4
2,911
Grade
3-2x4
8,820
2x6
998
2-2x6
4,559
3-2x6
13,716
2x8
1,315
2-2x8
5,988
3-2x8
17,869
Lumber dimensions:
2x10
1,676
2-2x10
7,610
3-2x10
22,499
2x12
2,039
2-2x12
9,255
Duration of load factor, Cd
3-2x12
27,363
4x4
7,497
4x6
11,723
4x8
15,368
4x10
19,485
Outdoors (wet service conditions)?
4x12
23,698
Beams and stringers
Fc (psi) =
1,100
Emin (psi) =
580,000
Unbraced height, KL (ft), x-axis
6x10
42,775
6x12
52,023
8x12
79,068
8.50
Posts and timbers
Unbraced height, KL (ft), y-axis Fc (psi) =
1,150
Emin (psi) =
580,000
6x6
26,137
8.50
6x8
34,454
8x8
52,866
For built-up columns:
8x10
67,450
10x10
91,529
10x12
111,319
12x12
139,048
Capacity calculation values for:
x-axis dimension = 5.5 in.
y-axis dimension = 3 in.
Cf or size factor = 1.1
Cm or wet service factor = 1
Cd or load duration factor = 1
See values of Fc above; F*c = Fc x Cf x Cm x Cd = 1870 psi
Values for x-axis buckling:
See values of E'min above. FcE = 0.822 x E'min / (le/d)^2 = 1649.1 psi.
For built-up columns only, the value of Kf = 1 for buckling about the x-axis.
Cp or stability factor includes Kf and equals: 0.646
Values for y-axis buckling:
See values of E'min above. FcE = 0.822 x E'min / (le/d)^2 = 490.64 psi.
For nailed built-up columns only, the value of Kf = 0.6 for buckling about the y-axis.
Cp or stability factor includes Kf and equals: 0.148
Capacity of 2-2x6 = F*c x minimum Cp x area = 1870 x 0.148 x 5.5 x 3 = 4559 lb.
Update Run Excel on the web server
Disclaimer: This calculator is not intended to be used for the design of actual structures, but only for schematic (preliminary) understanding of structural design principles. For the design of an actual structure, a competent professional should be consulted.
First posted July 1, 2008 | Last updated March 28, 2014
a 3.3 x 3.5 isnt the same as a 4x4 in a strength test.
Of course that is true. So what is your point? A link to the article would have been much more informative since the layout of your post is unreadable as to the context. Maybe it is my computer.
Engineers certainly understand the actual dimension of the material they are specifying. Construction codes are based on the actual dimension of the material specified.
2X4 is a name just like 4X4 or 3/4 inch plywood. The label does not say 2"X4". A stupid frivolous law suit that some greedy lawyer took on for money. Class action with only 3 plaintiffs? What a bunch of crap.
recurvearcher
Post by recurvearcher »
Dear Stetson Co.,
Regarding my newly purchased 10 gallon hat....
Hobbyman2
Post by Hobbyman2 »
Unless it is advertising?
Thanks for sharing .
Hobbyman2
Post by Hobbyman2 »
recurvearcher wrote:Dear Stetson Co.,
:D
Hobbyman2
Post by Hobbyman2 »
Might need to take test to buy a 10 gallon hat?
Hobbyman2
Post by Hobbyman2 »
As it turns out this is about labeling ..
I will retract my post on lumber strength since it doesnt pertain to labeling .
http://www.ien.com/supply-chain/video/2 ... mber-sizes
Simple fix for those who are not carpenters.
Thing is they still wont be able to buy a real 4x4
Maybe they will sue for the actual building formulas to be changed to?
Or because a 1/2 inch router bit is too big for a 1/2 board?
A 3.5"x3.5" 4x4 was 4"x4" when it was rough cut. The 2x4s used to be 1 5/8" x 3 5/8" too. That was back in my teen years. They are now 1 1/2"x3 1/2".
Capture True Dimensions.JPG (26.84 KiB) Viewed 10705 times
However, the way the court system has been working these days and with an uninformed jury (which won't be hard to seat), Menards and home Depot might lose this one. Surely there must have been a contractor involved. If there was, I wonder why he/she is not named in the lawsuit. A contractor would have more responsibility in this than plaintiff.
