everettdavis wrote:Did a little digging and found more, but do not know when it was introduced, or officially discontinued. Early M5's Mark 5's didn't have it. Later Mark V 500's didn't have it. Some did. The 1960's Mark VII did.
Support indicated that engineering felt it weakened the table and it was phased out, but before the current owners owned Shopsmith.
Not much help on establishing a date though.
Everett
You will never find it where the red "circle" is. It is on the other side of the table next to the head stock, ie on the left side.
I can also add that my machine from the factory new in 1976 had the two slots. I have a couple of machines from the late 1970's and early 1980's that do not have the slot but then the tables could have been swapped out since I got them used. The casting on them still have the place for the slot.
So, to summarize it in one place, the 'extra' BLADE slot was there in later Greenies, Goldies(Brownies), Magna American Graylings, Mark VII and early SS Inc. Mark 5's.
Fortunately the 505 - 520 tables and rails eliminated the need for it.
Well this one from a greenie did not have it - sn upper right. (=1954)
greenie table no slot.jpg (206.64 KiB) Viewed 20348 times
I as pertaining to the two slots that look like wide slots for saw blade or sander operation NOT the miter slots. Did I miss something in your information? Thanks for the follow up.
Tom
woodmeister wrote:I as pertaining to the two slots that look like wide slots for saw blade or sander operation NOT the miter slots. Did I miss something in your information? Thanks for the follow up.
Tom
Blade slot. I added that detail to the previous post.
There is no slot for the sanding disk on a Mark 5.
I realize it is an old thread, but I finally have some answers as to why a 2nd slot was there, and a date it was defined in a patent application. I believe they began producing it before they filed for patent application for it.
I will be posting the Patent Application later with some others that I have located since posting quite a few last week.
Everett
Reason for Second Slot in Tables beginning 1958 era.png (324.31 KiB) Viewed 8807 times
