Handy Lamp
Mike907
Handy Lamp
Post by Mike907 »
I just bought a lamp to use on the lathe (I don't use the Shopsmith as a lathe since I would have to raise it up on blocks), but it looks like it will be useful with the Shopsmith, too. The lamp has a switchable magnetic base with a V-notch, so it clamps onto the way tubes quite well.
Lamp Drill Press Mode 3.jpg (925.32 KiB) Viewed 22021 times
Lamp Extended.jpg (1.37 MiB) Viewed 22021 times
Lamp Bandsaw.jpg (848.67 KiB) Viewed 22021 times
https://woodturnerswonders.com/collecti ... lathe-lamp
The lamp is pricey, even at 20 percent off through 08/31, but seems to be of high quality.
Dansmith
Re: Handy Lamp
Post by Dansmith »
Very nice lamp. By the way, what do you use for a lathe?
Mike907
Re: Handy Lamp
Post by Mike907 »
I have a Jet 1221 midi lathe. It's on casters so I can put it away. If I ever get the space, I would like to get a bigger Jet or Powermatic. Jet now has the 1840DVR lathe with the same or similar motor to the PowerPro.
Dansmith
Re: Handy Lamp
Post by Dansmith »
Thanks, Mike. That lamp should work great for your lathe. I have occasionally thought of getting a big lathe; but, for now I am happy using my Shopsmith 10er with a speed changer that is doing what I need it to do, small bowls, tops, goblets and containers.
I guess if I stick with turning for the long term, and want to turn large bowls, I may have to consider a large lathe like the 2 you have mentioned. Of course, if money were no object, I wouldn't mind a Robust lathe. :D
the torch
Re: Handy Lamp
Post by the torch »
There is a problem with this shop ---??
I don`t see any dust.
A good lamp should show some dust.
masonsailor2
Re: Handy Lamp
Post by masonsailor2 »
Another tip for anything magnetic that you want to attach to the SS whether it be a fence or the table is use one of the t-slot slides. They are steel and work really well. The magnetic force pulls the slider up against the slot and locks it in place.
Paul
Re: Handy Lamp
masonsailor2 wrote:Another tip for anything magnetic that you want to attach to the SS whether it be a fence or the table is use one of the t-slot slides. They are steel and work really well. The magnetic force pulls the slider up against the slot and locks it in place.
Paul
See this post:
http://www.shopsmith.com/ss_forum/viewt ... mp#p164536
We must think a lot alike.
Re: Handy Lamp
GREAT IDEA!!!!!!
masonsailor2
Re: Handy Lamp
I liked the idea of this lamp so I ordered one. It arrived today, I attached it to the tubes, turned it on and it worked for about 5 minutes and died. Hopefully no one else is having this experience. Fortunately I ordered it through Amazon so getting it replaced should be fairly easy. I will try another on the bet this was a fluke because I do like the light.
Paul
jmattsson
Re: Handy Lamp
Post by jmattsson »
Received this as a b-day present from my son. I've used it for some intricate scroll saw work and really I like it. Attaching it to the way tubes works for the scroll saw, but not as well for the bandsaw. I need to find a better arrangement for the bandsaw. The light that is emitted is like artificial sunlight. Extremely bright, but no glare. Pricey, but I think it is worth it.
