cleaning rust
drnewton
cleaning rust
Post by drnewton »
I purchased a used mark V (1985). The main table has some rust on the legs (where the notches are.) What is a good, safe way to clean this up. It won't come off with elbow grease alone.
(By safe, I mean--I don't want the table to slip in the middle of sawing something.)
a1gutterman
Post by a1gutterman »
Hi drnewton,
This Sawdust Session may help you: http://www.shopsmithacademy.com/SS_Archives/SS114/SS114_Rust_Removal.htm
Tim
kevinkkm1
Post by kevinkkm1 »
you can try " fine " emery cloth on it with some WD-40 and then wipe with paint thinner and polish. If you can't get into any small holes with the sandpaper then try soaking the part in water mixed with Alka-Seltzer tablets for a day, then brush off the rust.
good luck
