Replacing the bearings on the drive sleeve
cityslicker2
Hey folks - my first post. I have a Mark V 1982 vintage that I bought used and I've been using for about 18 months. After watching Nick's sawdust segments on checking out used machines I decided to take my headstock apart. I found that I need to replace both bearings on the drive sleeve and I will also upgrade to the double bearing quill. Question - I ordered the bearings for the drive sleeve from SS. How are others removing and replacing these bearings? I have a gear puller and tried that on one of them and it wasn't budging? Any suggestions - should I find someone with a press or dedicated bearing puller? Thanks! Steve
- RobertTaylor
i've had good luck getting them off with a split type bearing puller in conjunction with a staight type gear/pulley puller. i use a socket that just clears the shaft and presses against the inner bearing race to press the new bearings on in a machinists vise. never press against the outer race or the covered side of your new bearings as you might damage them. bob
cityslicker2
Thanks Bob! I don't have a bearing splitter but may be able to borrow one. I can see where a splitter would help due to the limited clearance between the bearings and the sleeve for the belt. I also thought I could just see a split ring hard against the bearing on the quill end of the drive sleeve so I guess you have to be careful not to pull against that. Thanks again for the suggestion. Steve
cityslicker2
A friend with a press helped me pull the old bearings off and press on the new ones. I noticed that my drive sleeve is one that has an allen screw in the center portion of the drive and after removing one of the bearings we loosened the locking allen screw and slid the center of the drive sleeve over enough to get the arms of the gear puller over the other bearing.
This experience did help to much better understand the inner workings of the headstock and made me appreciate the engineering and craftsmanship of the machine. If I can help others with questions about this procedure I would be more than happy to do so. Steve
- RobertTaylor
great job steve. nothing like hands on experience. that along with information obtained here is how i learned. i'm going to modify my son's '56 model 500 this weekend to make it easier to maintain.
