What are the rarest Shopsmith accessories?
Re: What are the rarest Shopsmith accessories?
JPG, the arm and crank system is simpler to understand how to use and cheaper to make which is why I believe it became standard on later Model 10's.
All SPT's & 2 Power Stations
THANK YOU!jsburger wrote:YESJPG wrote:Let's see IIUC.
The rod is course adjusted and the block/disk small knurled knob(#2) or setscrew(#1) is tightened. Then the large knurled knob provides fine adjustment?
To say nothing re it being waaaaay cheaper.chapmanruss wrote:JPG, the arm and crank system is simpler to understand how to use and cheaper to make which is why I believe it became standard on later Model 10's.
- robinson46176
JPG wrote:To say nothing re it being waaaaay cheaper.chapmanruss wrote:JPG, the arm and crank system is simpler to understand how to use and cheaper to make which is why I believe it became standard on later Model 10's.
There seems to be a lot of broken ones out there... I keep my posts waxed but if I ever broke it I would redesign it.
I think the SPT Adapters and Power Mount Coupling kit are kind of rare.
- SPTAdapters.jpg (134.47 KiB) Viewed 5970 times
Shopsmith 10E S/N 5804 restored.
Shopsmith 10ER S/N R39267; purchased 10-10-50 in San Francisco.
Bruce Brenner
http://www.vintagepbks.com/shopsmith.html
Bruce Brenner
The SPT Adapter Kit Bruce shows is rare and the original coupler set is too but the coupler and hubs are still available today in their revised form.
