Free to a good home
STB
Free to a good home
Post by STB »
Found this at a garage sale thought someone that collects old Shopsmith things might like it. The tube has magna corp. on it so it's been around for a long time. If interested send private message.
100_0221 (800x600).jpg (330.54 KiB) Viewed 7726 times
100_0222 (800x600).jpg (282.92 KiB) Viewed 7726 times
Glenn
Re: Free to a good home
I think it might be white lithium grease.
The first Accessory Catalog I found it listed in is from July 52. It is not in the previous catalog I have which is DA-3-12-0151. The listing reads as follows
Magna-lube --
SHOPSMITH grease
Magna-Lube is a special grease for
SHOPSMITH drive sleeve, spindle
spline, and quill rack teeth, designed
for Magna by Standard Oil Company
of California. Apply only a small
amount of grease to rack.
12 048 -- Shpg. wt. 4 ozs. . . $ .50
Looking at the tube I have of it, I do not believe it is a white lithium grease but due to it's age it is hard to be sure. Mine is an unlabeled tube in a Magna box like the picture in the catalog listed above. The copyright 1953 catalog picture shows the tube labeled with a Magna box.
