Bandsaw table miter gauge
I purchased an older bandsaw with the smaller table. Wondered if you could use the miter gauge off my 510 with it or are you supposed to get a different miter gauge?
What kind of table does it have?
- RobertTaylor
you could indeed use your model 510 miter gage, however you would need to remove the washer that fits in the t-track of the 510 as it would prevent the bar from entering the slot on the cast iron table. it is very easy to remove/install with a screwdriver.
