Dust Collection needs - new shop setup
masonsailor2
Re: Dust Collection needs - new shop setup
Post by masonsailor2 »
Sorry I am coming in late on this one. A shop of 100 sg ft is going to require some special consideration on dust collection. Due to the cubic space in a small shop the concentration of dust particles goes up dramatically and therefore the so does the health and explosion risk. This is not the place to try and save money. In that size shop you have about 8-900 cubic feet of air space to deal with. A HF dust collector does 1750 cfm with the filter bag supplied which is in the 5-10 micron area. 5-10 micron is good enough to deal with the explosion risk but not even close on the health risk level. 1 micron is barely acceptable. The problem is that when you put a 1 micron filter bag on the cfm goes down dramatically. By my own experience it is about a 25 % reduction. Nothing scientific about the measurement but it is a very large reduction in air flow. The best solution is to put the dust collector outside the shop space where it vents to the outside and put a 30 micron bag on it to maximize the cfm. There are issues there also because of loss of heat or cooling depending on where you live and the noise level. I do both. I have a 1 micron filter that recirculates and a 30 micron that just evacuates the air to the outside. When I am doing operations that require a large amount of dust collection I turn them both on. But here in Vegas in the summer that means my shop can hit 90 degrees in a hurry and then I have to take a break and let the AC catch up. Remember that all the dust collection in the world will not keep you safe health wise. Heed Dusty’s warning and wear some sort of mask. Make it a good one. Again not the place to try and save money. As woodworkers we deal with some pretty toxic stuff. The dust from some woods is extremely toxic. Spalted woods are in a class by themselves. Keep in mind that spalting is caused by fungus.
Paul
djscruggs
Post by djscruggs »
Paul, this was so helpful. I think my description of the size of my space was inaccurate from a "dust containment" perspective. I've got a walled off area of my basement that is about 8 feet wide and and about 40 feet long....so I guess technically, its 320 sq feet. However, I only use the end of that space for woodworking, and the rest is storage, shelving, like a long, wide walkway with shelving on both sides. So I may have overstated the "concentration" from an air perspective. I don't have an option of venting to the outside unless I was to punch a hole in the brick wall, which I'm not inclined to do. I could vent to the other side of the internal cinder block wall and vent to the somewhat vented crawl space, but then, that only has flooring that separates the crawl space from my living room.
I really appreciate the feedback you have already provided. I'm wondering if you have any change of direction given the added input I just gave?
beeg
Post by beeg »
djscruggs
Post by djscruggs »
so very helpful! Tnx!
djscruggs
Post by djscruggs »
All of this input has been incredibly helpful, and I'm probably going to use almost all of it. I trust, based on all the input, that there is no such thing as overkill, but here's what I'm doing.
I bought a barely used HF dust collector that I've installed just on the other side of the cinder block wall. As the crow flies, its only 6 feet from my shopsmith. I will run 4" pipe to the other side of the wall where I will locate a cyclone. The pipe and flex tubing will connect to my shopsmith and all of its accessories, with another pipe and tube feeding a routing table and small drill press. On the other end of the shop, (my space is long and skinny....actually measures about 8 feet wide by about 15-20 feet of useable space....) I have a 12 gallon shop vac that I've also fitted with a small dust deputy knockoff cyclone. I can roll it out of the way and under my very long work table that spans the length of the shop. I also have a 3m respirator mask. This is all under construction as we speak. I've run all the wiring: added 2 20 amp circuits, and the electrician shows up on Monday to put it in the box and check my work so I don't blow my fool head off.
Last question: Have any of you had ANY experience with a cyclone that is basically a lid with two 4" holes, the incoming piece having a short run inside that directs the flow sideways in the bucket? The only compelling case for it is cost. The other alternative is the much more expensive dust deputy XL which runs about $250. At my woodworking supply store here, they only sell these lids as a cyclone alternative, which surprised me.
djscruggs wrote:All of this input has been incredibly helpful, and I'm probably going to use almost all of it. I trust, based on all the input, that there is no such thing as overkill, but here's what I'm doing.
Those 'lids' are a Thien(sp?) separator. AIUI they work fairly well.
rpd
Post by rpd »
This is the link to the Thien separator forum. http://www.jpthien.com/smf/index.php?board=1.0
djscruggs
Post by djscruggs »
ron, thanks for the referral to Thien!!!
I have had one of these for maybe 20 years. It fits the top of a 20"dia. garbage can. I don't always use it as it works better at chips then thing like sanding dust.
I did make a minor modification to mine, the ports were just holes that you stock the hose in but I added some hard attachments to make it easier for me to use.
dust one.jpg (267.87 KiB) Viewed 25445 times
dust two.jpg (199.71 KiB) Viewed 25445 times
