Rust on Rails
Rust on Rails
What is the best way to remove rust from the slide rails.
br549
Re: Rust on Rails
Welcome!
There are several methods, depending on the severity. Since you're new, may I suggest a little reading material:
https://drive.google.com/drive/folders/ ... xXuTMK4VmJ See next post by Everett (Moderator)
This is just one (and probably most complete) discussions of rust available here. The first three threads in the Maintenance and Repair Forum (stickies because they are always at the top) should be required reading for everyone.
- everettdavis
Re: Rust on Rails
You are most kind. I wrote that for exactly these kinds of requests.br549 wrote:Welcome!
I word of caution. Due to the size of the material, from time to time I reorganize it and move it between several locations within Google space I own. You listed a direct link to it's location, which gets there today, but sometime in the future, it will break.
That is why I have been so persistent in pointing folks to the Post titled "Shopsmith Large Format Drawings, Illustrations and More" post in the Maintenance and Repair Forum, where the Link My Google Drive appears. I ONLY update the active link attached to the My Google Drive under which sub-directories exist.
The Sub-directory is Rust & Paint where the file 'GotRust.PDF' is.
If one creates a link, please use the link https://www.shopsmith.com/ss_forum/view ... 90#p185690 to reach the post, then follow the My Google Drive link.
I hope the original poster finds the resources in that document to help them isolate and treat the rust problem they have.
Kindest Regards,
Everett
