Old MKVII motor
bigk01
Old MKVII motor
Post by bigk01 »
I haven’t torn into it yet, but I was using my ‘67 mkvii last week with a small wire wheel in the chuck, when one time when I went to turn it on it wouldn’t run in the forward rotation. It just hums and vibrates.
It seems to run fine in reverse.
I’m hopeful that it’s maybe just the switch.
I would appreciate any thoughts or suggestions from the experts before I take it apart.
K
BigK
1967 MK VII with Band Saw, 6 x 48 Belt Sander, Jointer and many small accessories
Ridgid Contractors Saw
Delta 9” RAS
2 DeWalt MBF RAS’s
14” Delta Drill Press
Re: Old MKVII motor
bigk01 wrote:I haven’t torn into it yet, but I was using my ‘67 mkvii last week with a small wire wheel in the chuck, when one time when I went to turn it on it wouldn’t run in the forward rotation. It just hums and vibrates.
K
Leave the motor alone!
Dive into the switch(not a pleasant task).
Do NOT do the hum test often nor 'longly'.
The contacts lose their spring with use/age.
VERY carefully 'form' the spring contacts.
If arcing has eroded the contacts, all bets are off.
bigk01
Re: Old MKVII motor
Post by bigk01 »
Thanks for the reply.
Believe me the last thing I want to do is mess with the motor.
As soon as I get a little time, I will pull the headstock and try to rebuild the switch.
Thanks again,
K
BigK
Delta 9” RAS
2 DeWalt MBF RAS’s
beeg
Re: Old MKVII motor
Post by beeg »
You don't need to pull the headstock. Just undo the nut holding the switch. BEFORE ya disconnect the switch, take a pic so ya know where the wires go back to.
Re: Old MKVII motor
beeg wrote:You don't need to pull the headstock. Just undo the nut holding the switch. BEFORE ya disconnect the switch, take a pic so ya know where the wires go back to.
ALL 8 or nine wires???? :D
beeg
Re: Old MKVII motor
Post by beeg »
YES!
or the next question will be "WHERE do these wires connect." :D :D
everettdavis
Re: Old MKVII motor
Post by everettdavis »
YES!
I can help with that just a bit. https://www.shopsmith.com/ss_forum/view ... 90#p185690
Follow the My Google Drive link, select the "Mark VII - 1960's vintage" folder
When you start seeing things like these..... download what you need. It's Free
There are even some blank motor wiring diagrams in case your colors are different that allow you to define what you have. Pictures are good, but colors sometimes get sketchy.
Everett
Mark VII Stuff.png (192.77 KiB) Viewed 22487 times
StevenAyres
Re: Old MKVII motor
Post by StevenAyres »
bigk01 wrote: one time when I went to turn it on it wouldn’t run in the forward rotation. It just hums and vibrates.
I had the same experience shortly after I started using my VII. After checking out the wiring carefully, I narrowed the problem down to the start capacitor. Mine was a GE motor.
Re: Old MKVII motor
Ah, but, his only fails in ONE direction, hence the switch is de prime suspect.
bigk01
Re: Old MKVII motor
Post by bigk01 »
Thanks again to everyone who has replied.
I just took a quick look and I can’t see anyway to get at the switch without talking the headstock off the rails. It doesn’t look like the motor cover will drop between the lower tubes.
Am I missing something?
It’s a little tough wrestling the headstock by myself, but I have done it before.
BigK
Delta 9” RAS
2 DeWalt MBF RAS’s
