posting problems?
posting problems?
Anyone having problems posting this afternoon/evening?
Re: posting problems?
This is what I'm seeing on a post I'm trying to post:
ScreenHunter 181.jpg (13.8 KiB) Viewed 10758 times
The post in question seems to have made it to the forum despite the error message??? Anyway I work on the next follow up post a bit later tonight so we will see if I see this error message again or not. And yes this thread seems to not have the issue.
mountainbreeze
Post by mountainbreeze »
On the surface, I find this a bit comical . How does one post about having posting problems?
As indicated by your subsequent post, I don't believe you have a posting problem. It appears to me that your failed post was simply rejected for "some reason unknown". If you could attempt another post exactly the same as the one rejected and it too gets rejected then I would be proven "WRONG".
Until then I think this was just a quirk.
What file did you attempt to access?
