Floor Lamp on ShopSmith
Hello All,
I started small on the lathe and now want to make a floor lamp. How do you make a tall lamp post with the wire in the middle in segments that will last?
Yes I'm still green.
- BuckeyeDennis
Re: Floor Lamp on ShopSmith
I’d run a long piece of lamp pipe up the middle. It can serve as both a conduit for the wire, and as an end clamp for your turned lamppost segments.
This place seems to have a good selection of them.
Hi,
Just commenting here... You'll possibly be challenged on keeping the thing "bottom heavy" enough to avoid tipping.
Here was an alternate Shopsmith-assisted way I did a lamp base:
https://www.shopsmith.com/ss_forum/view ... =5&t=20889
Best Regards
Chris
Best Regards
Chris
Thanks for the info guys.
Glued tennon segments on a wide base sound about right?
Update
Finished product
1st piece of furniture
Finished product
- Floor Lamp.jpg (209.4 KiB) Viewed 50888 times
Nice looking table and functional. Did you turn the spindles too?
Great job!
Yes.stew wrote:Nice looking table and functional. Did you turn the spindles too?
I really like turning now.
Good job of turning!
I'm always impressed with turn pieces.
John
John
You could make the lamp post in segments, drilling a hole through each for the wire, and use strong joinery like dowels or screws to hold them together.
