Model 7
dannyshamoon
Model 7
Post by dannyshamoon »
Dumb question, is there anything i would use a new digital motor for other than lathe work for slower speeds and reverse operation?
Thanks
Danny
rjent
Re: Model 7
Post by rjent »
No dumb questions LOL
10000 RPM for routing/shaping
menu driven speed (con in my opinion)
Powerful and high torque across the RPM band.
Quiet.
Reversing
Cons:
Reliability
Pay for support
To name a few :)
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
garys
Re: Model 7
Post by garys »
rjent pretty much covered it. The higher and lower speeds would be very useful as well as more power. I personally don't think I would ever use the reverse feature, but if I had it, I might some day.
Re: Model 7
I do use the reverse on mine with the Strip Sander for sharpening lathe chisels.
Spooner
Re: Model 7
Post by Spooner »
I don't know a lot but I read it ramps up to speed drawing lower amps and thus not popping your breaker. I also read that it sense if it needs more power to maintain speed thus giving you a more consistent cut. It won't bog down. Less burning.
dannyshamoon
Re: Model 7
Thanks guys. I have a hand router that does 10k rpm. Instead of spending $1,600 for the upgrade I thought I would buy a digital motor lathe for $600. It reverses, has speeds from 400 to 3,900. I figured it would work fine for my pen and bottle stoppers and I can an extension bed for doing longer turns.
Danny
