I am having a problem with my Mark VII idler shaft moving in and out of the idler shaft sheave. The idler sheave on the Mark 5/V has a retaining clip that holds the sheave on the shaft. This Mark VII does not. The set screw holding the bearings inside the idler shaft is tight. I thought about machining the shaft to accept a retaining clip or adding a set screw on the poly v side of the sheave. Anyone already have an alternate work around or had the same issue.
Mark VII Idler Shaft moves in Idler Shaft Sheave
- IMG_0332 resized.jpg (112.24 KiB) Viewed 7865 times
Re: Mark VII Idler Shaft moves in Idler Shaft Sheave
The setscrew only secures the bearing SPACER.
JPG wrote:M VII IDLER SHAFT BEARING RETAINER.jpg
I was sure you would have the solution. I’ll try to get it done soon. Thanks Roger
Replacing the clip on the idler shaft turned out to be a much easier job than I anticipated. After loosening the belts, removing the retaining screw, and the nut and washer from the idler shaft I was able to lift the bearing block out exposing the shaft.
Several years ago I picked up a beater Mark VII for the motor. I tore that idler shaft apart before my initial post but couldn't tell there had ever been a slot for the clip hence the original question.
Thanks again JPG for the help.
Ah yes. I also have one of those boogered shafts.redleg wrote:Replacing the clip on the idler shaft turned out to be a much easier job than I anticipated. After loosening the belts, removing the retaining screw, and the nut and washer from the idler shaft I was able to lift the bearing block out exposing the shaft.
$matches[2]
