Hook and Loop
Spooner
Hook and Loop
Post by Spooner »
Are any of SS's 12" Disc Sanders Hook and Loop or are they all adhesive?
Re: Hook and Loop
Spooner
Re: Hook and Loop
Post by Spooner »
So there isn't an actual disc you have to buy the disk and then buy the conversion kit? Correct?
Re: Hook and Loop
What you didn't ask was if they are a good idea for your shop. I'm guessing this is more then likely a question that if not you then others have on their minds.
The answer is? As almost always, it depends.
I have one and it is nice to swap papers on, and if you want or don't mind soft corners. They are not for sharpening. They are not for trying to take off a lot in a singe pass. And yes you can wreck them if you get too carried away forcing the material into them. While I have not had that issue it is purely that I know better.
I have a whole stack of sanding disks. One for each grit and one for sharpening and I still have a older 500 length one. I have two of the conical disks one for each of the grits I use.
The Velcro system is not a substitute for but only perhaps an addition to a regular sanding disk or 3 or 4. I would not want it as my only disk sander.
wa2crk
Re: Hook and Loop
Post by wa2crk »
Try the link below.I have used two of their conversions and have been very satisfied
https://www.supergrit.com/products/prod ... conversion
Spooner
Re: Hook and Loop
Post by Spooner »
wow all things I hadn't thought of or didn't know... Thanks Ed.
Thanks for the links too guys.
Spooner
Re: Hook and Loop
Post by Spooner »
So when it comes to sanding discs what does PSA stand for?
P89DC
Re: Hook and Loop
Post by P89DC »
From the google:
sanding discs are designed with PSA (pressure sensitive adhesive) backing for easy, secure attachment
Spooner
Re: Hook and Loop
Post by Spooner »
Pressure Sensitive Adhesive. Yeah... I knew that. LOL... Thanks P89DC... It aaaaaallllll makes sense now.
