Raised Planter Bed
WoodFrog
Raised Planter Bed
Post by WoodFrog »
My wife was super excited and supportive of me getting a Shopsmith. I figured there had to be a catch...the first project she commissioned me to build was a raised bed planter. She found a design by Janet Fox she liked on this site by Ana White.
https://ana-white.com/woodworking-proje ... -janet-fox
I got it built, see pictures below! I left a bit of a gap on the corners to attach small posts if I end up needing to put some wire around it to keep critters out, otherwise identical to the original design.
I used Fir posts and Cedar on the rest of it.
Share 1.jpg (261.32 KiB) Viewed 11397 times
Share 2.jpg (329.22 KiB) Viewed 11397 times
WoodFrog :D
thunderbirdbat
Re: Raised Planter Bed
Post by thunderbirdbat »
Very nice. Dome of clear or opaque plastic will give you a hot house or cold frame for starting plants or to extend the growing season.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
rjent
Post by rjent »
That looks great! Like Brenda points out, lots of uses.
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
john
Post by john »
[b]Looks Good![/b]
Your wife should enjoy working with that.
Our planter boxes are not raised but I think we are getting to the point that we may need to. Also, I notice that this design leaves room underneath for storage of accessories that may be handy to keep nearby. Another reason to consider a raised bed.
John
WoodFrog
Post by WoodFrog »
Thanks guys! Yeah, good idea on the plastic to make a little mini greenhouse. I will have to look into the plastic. Are you talking a thin and flexible plastic film or like harder sheet of plastic w/ some structure to it?
WoodFrog :D
thunderbirdbat
WoodFrog wrote:Thanks guys! Yeah, good idea on the plastic to make a little mini greenhouse. I will have to look into the plastic. Are you talking a thin and flexible plastic film or like harder sheet of plastic w/ some structure to it?
WoodFrog :D
I have seen people use just a clear or white thin plastic sheet (3mm drop cloth sheet), acrylic sheets, glass, greenhouse twinwall panels and corrugated polycarbonate panels. It all depends on how fancy you want to get and what you have on hand. Cheap, quick and easily repaired/replaced is bent pvc or bamboo covered in plastic sheeting. Easy to roll up the sides when it gets warm to vent the heat too. I saw a fancy one someplace with greenhouse twinwall panels and automatic vents like a large greenhouse that I thought was overkill on a raised bed like yours. An other one I saw the person had used old house windows to make a greenhouse cover for it.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
rjent
Post by rjent »
Make a simple frame and staple plastic sheet to it. make it removable and you can get seeds started pretty early. I did it with earthboxes years ago, but the same thing here. Have fun!
Dick
1951 jigsaw X 2
zoeymiler45
Post by zoeymiler45 »
Too good dear.
