Greetings everyone,
In part of my preparation to retire I am disassembling my fathers mark five. It has been idle for many years and needs some TLC which will be my first project in retirement. Are there any special tips I should know before I attempt to remove the power unit from the tubes?
Thanks in advance for any help.
John
Moving
Re: Moving
One tip: if the end bracket ("way bar tie") doesn't want to come off the end of the way tubes, don't beat on the webbing between the tubes. The part is brittle.
Re: Moving
Thank you, it was actually easier that I was expecting everything came apart with no problems. Hopefully it goes back together as well.john_001 wrote:One tip: if the end bracket ("way bar tie") doesn't want to come off the end of the way tubes, don't beat on the webbing between the tubes. The part is brittle.
John
