Chad
Roy Underhill calls "BS" on old Shopsmith Informercial! (He's Right!)
Post by Chad »
Watch it here: https://youtu.be/LDj_o2OMCCU
🎬 PLEASE visit and view Steve's interview with Roy on "The Woodworking Talk Show" on Steve's channel: https://youtu.be/3qKChn4qbKA And thanks in advance to Steve for not making a copyright claim on this video. (Please!)
🎬 Here's the old Shopsmith infomercial: https://youtu.be/TsxE74mRXts
edma194
Re: My Growth Rings with Scott Markwood
Post by edma194 »
Have to find time to watch the whole interview with Roy Underhill. I love The Woodwright's Shop and Roy is just fantastic, and the history of tools fascinates me. I wish he had better impressions of his father's Shopsmith and didn't only remember a dumb statement in an old informercial. Of course he's right about that statement. Real 90s informercial-ly type of statement that I'm sure they all regret now.
Chad
FOUND! Shopsmith legend Doug Reid on all things Shopsmith
Post by Chad »
Watch it here: https://youtu.be/-pFWmXpoBuI
Doug Reid has sold Shopsmith tools to THOUSANDS of woodworkers across the USA, and his Youtube channel has garnered over 1 1/2 Millon views! Join me as I chat and catch up with Doug and be sure to visit and subscribe to Doug's channel here: https://www.youtube.com/c/DougReidsho...
🎬 Here's the old Shopsmith infomercial we referenced: https://youtu.be/TsxE74mRXts
Chad
"You probably can't afford a Shopsmith..." My favorite Doug Reid Outtake
Post by Chad »
Watch it here: https://youtu.be/_hJOhmqduvA
When Doug Reid and I met last week to record this past weekend's video we chatted for an hour and a half so some fun parts of the conversation wound up on the cutting room floor. This outtake was one of my favorites, so here it is after all!
Here's the link to the final version of the video: https://youtu.be/-pFWmXpoBuI
Chad
Nick Engler from "Workshop Companion" talks Shopsmith, woodworking education & more
Post by Chad »
Watch it here: https://youtu.be/-UA5ZIFJCfA
Popular author and educator Nick Engler reminisces about his years at power tool manufacturer Shopsmith and brings us up to speed on the launch of his "Workshop Companion" Youtube channel and more. Check it out and subscribe here: https://www.youtube.com/c/WorkshopCom...
🟢 Be sure to explore Nick's vast catalog of woodworking books: https://amzn.to/3py2Hwn
🔴 Please consider joining the 100+ other channel members in supporting the channel and get access to perks: https://www.youtube.com/channel/UCGsm...
Chad
Raised Panels with "Vertical" router bits on a Horizontal Router Table
Post by Chad »
Watch it here: https://youtu.be/f6wSnVCTFRQ
Routing beautiful raised panels for doors or wainscoting can be intimidating with high HP routers and large diameter bits. And the cost of those large diameter bits can also give you pause, which is why "vertical" raised panel router bits were introduced. They can be powered by lower HP, non-variable speed router motors, but now they introduce challenges brought on by having to guide the wood through the router table on edge. Using a horizontal router table, like my old Shopsmith Joint-Matic can be the perfect companion to these bits.
Re: Raised Panels with "Vertical" router bits on a Horizontal Router Table
Chad wrote: Mon Nov 01, 2021 7:35 am 128.jpg
Wonder how much CFM is being blocked by the extra table etc.
A DC might work better than that vac!
thedovetailjoint
Post by thedovetailjoint »
JPG wrote: Mon Nov 01, 2021 12:52 pm
I think that’s a good point about the auxiliary table possibly causing some constriction. Since all of the air being collected has to pass through either the hole in the slide or around the openings in the base on the back, the path of least resistance is probably the base. I think I need to tape those openings shut and try again. It really is a tight fit on the front with these anti-kickback bits. And yes, I’m sure that a DC3000 or most any dust collector would be an improvement. Scott
http://www.Youtube.com/user/MyGrowthRings
http://Shopsmith-Tool-Hunter.Blogspot.com
http://www.Tool-Hunter.com
I think tapering the open slot to the same dimension as the jointmatic base hole at the bottom would help. Enough? Only the shadow knows.
All the air flow MUST come from that path since the top is obstructed by the workpiece.(IIRC)
P.S. the very small area of the 'tunnel' is restricting. Maybe making it 'deeper' (if even possible).
edma194
Post by edma194 »
So he makes an auxiliary table so he can use a miter gauge and then doesn't use a miter gauge. Then the sharp edges of the auxiliary table where it was cut for the miter track leaves score marks on the wood. Isn't just as easy to not make the auxiliary table, not use a miter gauge, and then make the score marks with a knife? :p ;)
