Pro Planer Knife alignment issues.
killscreen123
Post by killscreen123 »
Hello Everyone,
Finally got around to replacing my very worn Shopsmith pro planer knives with a new set. I've never done this before. Having inherited all of my grandfather's shopsmith tools, I cant seem to find the knife setting guide that comes with these planers. I watched the video of Nick Engler using a dial indicator to set the knives, so I went out and bought one with extra tips to try my hand at changing them.
I followed the video as best I could, and managed to get all of the blades within one or two thousands of an inch. Satisfied, I put it all together to test it out.
When I fed my test board in, the rollers of the planer did not contact the board, but the knives cut the wood, kicking back the wood gently. I tried a few more things, but still the rollers would not contact and the knives would cut/kickback. I figured the new blades were longer, so I just have to adjust the thickness scale as per the manual. Well I can't adjust the scale anymore, it reads about 1/4" thicker than the wood actually is.
Can anyone tell me what's going wrong? I can't adjust the height of the rollers, only the pressure they press down with. I'm assuming I set my knives too high, as they will cut before the rollers contact the wood. As per Nick's video, I set the dial indicator on the highest point of the knife, and went about raising the knife until the dial indicator made one full revolution + 32 thousandths. Did I misinterpret Nick's instructions?
Thank you for your time!
Re: Pro Planer Knife alignment issues.
I have to think so on both accounts.
Yes the rollers are only adjustable for tension.
1/4" Good Grief!
0.032/revolution?????
Setting the scale is done as the LAST thing. If the knives are set properly the scale should NEVER need to be adjusted.
How far proud of the cutter head are the knives protruding?
killscreen123
It would seem the knives are cutting 1/4" before the rollers catch, which I assume is why the scale is so off.
On watching Nick's video again, I think I've found where I've messed up. Nick sets the dial indicator to 0.0068" on the cutter head BEFORE the knife. Then, he proceeds to rotate the cutter head so that the highest point of the knife is pressing against the dial indicator tip, and proceeds to make his adjustments.
I was setting the dial indicator to 0.0068" directly on the knife, which is incorrect, it should be set on the CUTTER HEAD and NOT the knife. I'm quite positive this is the step that I missed, which gave me the terrible results I got. I will return to the shop with this new knowledge and report back on any change!
If you get it figured out using the dial indicator great. If not consider getting the Planer Knife Setting Gauge. It is part number 512414 and sells for $8.99 here on the Shopsmith website. It is very easy to use.
It is shown in the picture below.
_
513414 SS pic.jpg (3.4 KiB) Viewed 4041 times
killscreen123
Hey everyone,
As mentioned above, I went back and used the dial indicator the proper way after watching Nick's video again. Everything went perfect and the problem is solved!
Thanks for your help!
killscreen123 wrote: Sun Jan 10, 2021 4:56 pm Hey everyone,
This is so good to hear. I read your posts three or four times and had NO IDEA what might be wrong.
garys
Post by garys »
I picked up a 1985 planer a few of years ago and somewhere along the line the alignment tool disappeared and was no longer with the planer. I simply ordered a new one from Shopsmith. A year or two after getting it, I decided that the blades needed sharpening so I pulled them out, had them sharpened, and reinstalled them using the alignment tool. It worked perfectly, and is still the simplest way to do the job. I highly recommend getting and using the tool from Shopsmith.
JohnEMT
Post by JohnEMT »
Chapmanruss
I purchases the Planer Knife Setting Gauge you showed in your response to Dusty, but when I received it, it did not have any instructions on how to use it. Do you have any instructions on how to use it or is there a Shop Smith video on how to use it with a Mark V Planer.
JohnEMT
The alignment instructions are in the Owner's Manual. It is the same for either the Mark Mount Planer or the Pro Planer. Unfortunately, the Manual for the Planer is currently not available here on the Shopsmith Website for either download or purchase. If you don't have a manual, you could try buying a used one since it is not available. Either the Mark Mount or Pro manual would work for all of the functions and alignment except mounting on the Mark or the stand with motor depending on which planer you have and which manual you find.
A PDF copy of the Professional Planer Manual is linked below. The Alignment Instructions are in the Maintenance Section beginning on page 28.
PL-5126 5-92 Pro Planer Owners Manual.pdf
(1.7 MiB) Downloaded 1539 times
The PDF copy I have of the Mark Mount Planer is too large to post here. If Shopsmith objects to my posting of the 1992 Pro Planer Manual I will remove it.
RFGuy
Post by RFGuy »
chapmanruss wrote: Sun Jan 10, 2021 2:03 pm If you get it figured out using the dial indicator great. If not consider getting the Planer Knife Setting Gauge. It is part number 512414 and sells for $8.99 here on the Shopsmith website. It is very easy to use.
_
Sounds like the OP was able to dial (pun intended) in their planer knives, but in case anyone else stumbles on this thread in the future...I found it helpful to use a printable ruler that I taped to my planer knife setting gauge for the reasons stated in the thread linked below. Hope this helps someone as it did me.
viewtopic.php?p=265392#p265392
📶RF Guy
