pen turning mandrel problem
rdewinter
Post by rdewinter »
I'm trying to turn some pens for Christmas presents. Having trouble finding the best solution to attach a #2 morse 7mm mandrel to the headstock. Currently using a saw blade arbor to hold mandrel but it's not the best solution. The #2 mandrel won't fit into the drill chuck, so that's not a option.
[ATTACH]2382[/ATTACH]
Any suggestions for attaching mandrel to headstock?
I know I need to replace the dead center in the tailstock with a live center.
San Diego
pen mandrel.jpg (90.03 KiB) Viewed 11018 times
paulmcohen
Post by paulmcohen »
See if you can remove the rod from the #2 Morse taper part, the mandrels for the Shopsmith either come without that part of have a 5/8" hole like the other Shopsmith accessories.
Paul Cohen
Beaverton, OR
curiousgeorge
Post by curiousgeorge »
Bob,
You are in luck. Penn State Industries has the Shopsmith pen turning mandrel on sale right now for $17.95, reg. $24.95 ...
http://www.pennstateind.com/store/PKM-CL.html
George
Ft. Worth, TX.
Go TCU Froggies
rdewinter
Post by rdewinter »
Paul,
If I read your post correctly, yes I can unscrew the rod from the #2 Morse taper part, then just chuck the rod into my 1/2" chuck and use that to power the mandrel. That's brilliant! That's what I love about this forum, people who use their brains and experience and share it. Thank you.
San Diego
kd6vpe
Post by kd6vpe »
Well folks,
I had just ordered the PennState mandrel myself to try to make pens. Here is what I did yesterday. I fount the mandrel to work out just fine on the shopsmth in fact the set screw is the right size for the shopsmith. I used a woodrcraft kit with the mandrel and everything fit fine. I plan on using this pencil for marking my turnings it's fat and study. Next I will move on to the pens for gifts. I was a lot of fun just have to pay attention to the drilling part. I wasted a few peirces of wood until I got it right. Have fun.
Jim
SS 500 upgraded to 510; SS bandsaw; SS jointer
SS Oscillating Drum Sander; Universal Lathe Rest;
lathe duplicatior, shaper fence and shapers; SS Belt
Sander
Jim
www.youtube.com/kd6vpe
curiousgeorge
rdewinter wrote:Paul,
San Diego
Thank you for your answer George, but I think I will try Paul's suggestion first.:rolleyes:
George
Ft. Worth, TX.
Go TCU Froggies
paulmcohen
Even though I suggested using your drill chuck it is not a good long term solution. A drill chuck is not designed for side pressure.
Paul Cohen
Beaverton, OR
ryanbp01
Post by ryanbp01 »
Can't you unscrew the mandrel from the taper and insert the shaft into the chuck? I don't use the tapers. I haven't had any problems using the chuck to hold the shaft.
BPR
jbooher
Post by jbooher »
Yes you can take the morse 2 taper off and used your drill chuck.
James
curiousgeorge
ryanbp01 wrote:Can't you unscrew the mandrel from the taper and insert the shaft into the chuck? I don't use the tapers. I haven't had any problems using the chuck to hold the shaft.
BPR
In the post previous to yours, Paul stated that you could do this. But, it is not a good long term solution because the drill chuck was not made to take the sideways pressure caused from lathe work. Yes, it will work for a while but eventually your chuck will break. So, why not just go ahead and buy a mandrel that will fit your Shopsmith and do it right? It will save you not having to buy a new drill chuck AND a mandrel later.:D
George
Ft. Worth, TX.
Go TCU Froggies
