I have a Mark V 500 that has a sheave pulley that rubs/vibrates against its motor face. This mainly happens late in the lower part of the RPM range when the spring is compressed. Is this sheave pulley to motor face rubbing normal or should I be concerned about it? It appears like the spring resonates and pushes the sheave pulley into the motor. Should the spring have a dampener?
Thanks,
Ryan
how do I prevent sheave pulley from rubbing against motor face?
- Bronze Member
Re: how do I prevent sheave pulley from rubbing against motor face?
There is a spacer between the motor bearing inner race and the fan sheave. A known problem is the spacer embeds it self into the soft aluminum sheave. The spacer needs to be replaced. Newer spacers are thicker.
- Bronze Member
JPG,
Thanks for the information. Is the spacer commonly available or do I need to order it from Shopsmith?
Thanks,
Ryan
Thanks,
Ryan
There is a work around. viewtopic.php?f=10&t=11986
Scroll waaaaay down
Otherwise get a new one from SS
Scroll waaaaay down
