I have picked up two used SS.
I understand date of Manufacture can be determined from serial number but can find no info.
1st 183784
2nd 58821
Also the 1st has a much heavier and larger table saw base and fence along with larger ext. tables. Is this a diff model or just some type of upgrade?
How does the drill chuck get connected to spindle?
Thanks in advance
Used SS from newbee
The first one was built in the 1983-1984 time period and the 2nd was built between 1980 and 1981.bob22 wrote:I have picked up two used SS.
1st 183784
2nd 58821
Thanks in advance
http://www.shopsmith.com/ownersite/serialnumber.htm
http://www.shopsmith.com/ownersite/faq/markv.htm
http://www.shopsmith.com/ownersite/toolhistory.htm
Hope these references help.
All the MKV's are the same basic unit. Which I think we determined is the 505 now. So it seems as you have a 500 and a 505.
The chuck just slips on the spindle and locks down with a set screw.
