When cross cutting veneered plywood I score the cut line with a sharp knife and then cut on the "scrap side" of the score.
Doing this is almost a necessity (at least for me) when using Box Store plywood. With quality grade plywood such as that from Woodworkers Source I find it less necessary. Sadly, when you discover that it was necessary it is too late.
Nice job though even if you did have some splinters.
Window surround
Re: Window surround
Re: Window surround
How are you planning to use the bottom section(s)?
Re: Window surround
I have a few large plastic storage totes that will fit the bays.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
1998 bandsaw
2016 beltsander
jointer
overarm pin router
Re: Window surround
Great Job!
Good idea taking pictures of the assembly process. I never think of taking pictures until something is done.
Looks super. I love the way Red Oak plywood looks.
Red Oak ply wood is what I used also. I too scored with a utility knife before I dadoed. Kind of a pain but necessary after trying a sample cut.
I only did two shelves that way, the rest were holes and shelf brackets. I'm not smart enough to figure where I want the shelves.
Now trim the edges with cherry and it will look a lot like the one I did.
