Excellent! Thank you Russ. I have found it to be very helpful and now I don’t have to worry about losing the link or being on a computer where I don’t have it bookmarked.chapmanruss wrote: ↑Tue Jul 20, 2021 12:45 pm The thread Everything E/ER - Technical Info, Documentation, Links in Maintenance and Repair is now pinned to the first four topics for easy reference.
Complete Rookie - Shopsmith 10ER Lathe/Drill Press
Re: Complete Rookie - Shopsmith 10ER Lathe/Drill Press
Marc Jones
Gee I wonder how it got "stuck"?
Thank You Admin!
Thank You Admin!
Yes, Thank you Admin. I only reported it had been done. Admin is the only one that can do it.
All SPT's & 2 Power Stations
Aaahhh, I see. Yes, thank you Admin. I thought that since Russ has been so active and helpful that he might actually be an admin. Because of his thorough histories I see him as the ShopSmith historian while Everett is the ShopSmith Archivist. I have much gratitude to both of them for their efforts, just as I do for all the other detailed help provided by several others. This just shows that this is a member supported board, and we are lucky to have an admin that keeps close tabs on our discussions and continues to do things that are helpful. Many thanks to you all.
Marc Jones
Well admin does respond to PMs.
- Silver Member
Thanks to all of you for your knowledge, experience, and help! I'm sure there will more to come!
- Bronze Member
I'm not (yet) a Model 10 guy, but isn't there some type of tailstock center in the OP's pic? crack with jack jiofi.local.html
YES.
