Need chuck help
seafish
Need chuck help
Post by seafish »
I am new, I know nothing.
Had a Supershop machine gifted to me, have very little information (diagrams, parts list) about this machine.
The chuck that came with it had square non self aligning, maybe designed more for metal work?
I purchased a 556212 Nova G3 Lathe Chuck Package self aligning chuck from Shopsmith.
I had expected it to fit, screw on easily, have the correct adapter.
When I remove the original chuck I have threads that have a diameter of about 2 1/4 inches.
The rod that enter from the left end of the motor unit and screws into the back of the chuck on the right side of the motor unit is about a 1/2 in diameter.
I am sure I have used incorrect terms and have not described the issue fully, but if someone has some help it will be appreciated.
edma194
Re: Need chuck help
Post by edma194 »
I don't know any details about the Supershop but the original chuck you describe sounds like a typical metal lathe chuck with a wide center hole that allows pieces to pass through the chuck for various purposes. Non-self centering chucks are also common on metal lathes. The Nova chuck is a typical wood lathe chuck that doesn't have any center hole but is self-centering.
You can go to this forum page and click on the red My Google Drive link just below the title. You'll find a folder on that page for FoxSuperShop that contains a manual and other information.
Is a self-centering chuck your goal? Is there some other reason to use the Nova chuck?
Before I broach other possibilities I see that the manual I indicated above points out that a screw center can be mounted in a collet chuck. I'm sure other centers can be mounted that way, and possibly a simple 5/8" secondary adapter you could make for the Nova chuck. I recall this has been done for using a variety of Shopsmith accessories on the Supershop. So, do you have the collet chuck that the machine had originally? Whatever you do with this machine you will probably want to acquire one if you don't have one now.
ETA: I have assumed you want to use the Nova chuck for wood turning. I do not think it has been designed for metal working use.
rpd
Re: Need chuck help
Post by rpd »
Here is a link to the Super Shop manual that you can download.
https://cdn.shopify.com/s/files/1/1845/ ... al.pdf?149
And this post on Lumberjocks may be helpful, scroll down to comment #15 in particular
https://www.lumberjocks.com/topics/64710
lavetarucker
Re: Need chuck help
Post by lavetarucker »
edma194 wrote: Sun Nov 28, 2021 1:50 pm I don't know any details about the Supershop but the original chuck you describe sounds like a typical metal lathe chuck with a wide center hole that allows pieces to pass through the chuck for various purposes. Non-self centering chucks are also common on metal lathes. The Nova chuck is a typical wood lathe chuck that doesn't have any center hole but is self-centering.
I had the same issue, the thin guide really helps.
lahola1
Re: Need chuck help
Post by lahola1 »
Your supershop should have an R8 collet with it . R8 collets are used in the metal industry and come I.D.s of various sizes. These collet slips into the supershop quill and are locked down with the long 1/2" rod from the back.
I don't know much about the nova chuck but if it has 5/8" ID to lock onto a Shopsmith 5/8" shaft I would get a short (apprx 6") piece of 5/8" steel rod
and If you have a collet with a 5/8" ID I would lock the 5/8" rod into a 5/8" ID collet with about 1 1/2" sticking out to lock the novachuck onto like a shopsmith.
If you don't have a 5/8" ID collect you can get them reasonbly priced on Amazon or Ebay. I bought some for my Supershop there.
If I'm wrong about the novachuck hopefully someone will correct me.
SS Mark VII(sn 405025), SSband saw, SS 4" jointer, Older SS Mark V w/DC treadmill motor,
Smithy SuperShop 720, Powerkraft RAS,Craftsman RAS, Ridgid TS2412 Table Saw,
Delta 12" planer
