DC-3300 to DC-6000 upgrade: Yea or Nay?
- SteveMaryland
Re: DC-3300 to DC-6000 upgrade: Yea or Nay?
A pressure vs flow "pump curve" describes all the "operating points" of the pump or compressor. Ideally we want to run the "system" (pump, pipes, valves etc) at the point on the curve where the product of flow X pressure is a maximum. The attached jpg, previously displayed, shows (approximately) where that op point is.
Every pump fan, compressor has such a curve, either supplied by the mfgr or can be plotted from measurements.
In reality, keeping the system working exactly on that best op point is impossible. If we want more flow or pressure, we must get away from that op point.
- Capture.GIF (60.18 KiB) Viewed 2293 times
I frequently run TS and Jointer in tandem on a Mark and my router table also has two connections. I definitely see an improvement for both of those using two hoses in comparison to the 3300. I don't have, and have never had, the lower saw guard with two connections, so can't speak on that specifically. I had noticed in one of your pics in another thread that you have quite a bit of escaped dust on your TS compared to what I think is normal (520 setup). But I don't have great collection on my TS either.Majones1 wrote: ↑Fri Dec 31, 2021 11:18 am Back to an earlier point about how many of us can use only a single hose in our small shops and therefore conclude the DC-6000 wouldn’t give us any advantage over what we have with our DC-3300. That is mostly true for me, but I have a Mk5 500 and the upgraded lower blade guard/dust collector attachment has two hose ports that definitely increase the dust collection effectiveness. Even with this better dust collection, a lot of dust still makes it’s way outside the guard/DC attachment. It is here where I would think that the increased CFM might be beneficial. Is there anyone here on the forum who can speak to this configuration?
One member (claimdude?) uses the DC-6000 with no plenum and a 4" hose, with reducer near the tool for a single hose setup. I have not tried this yet but I believe it would be significantly better as a single hose setup. (Not recommended for the DC-3300. IIUC air velocity in the 4" line is known or believed to be too low to keep the dust suspended.)
This is a post I was looking for earlier: viewtopic.php?p=285543#p285543 It is on an unmodified DC-3300, except for the large filter hood. One of the few posts recently with actual instrumentation, though no photos. Of significant note: RFGuy measured more than double the airflow with the plenum removed Vs the combined total of the three ports. While the combined area of the three ports is comparable to the single port with plenum removed. If accurate, that would suggest something unexpected, perhaps turbulence(?), in the plenum. Someone that aced fluid dynamics could weigh in on this...
Note: RFGuy has been silent recently on the forum. I hope that everything is okay. I sensed that he might have been perturbed with the direction another thread went. I hope, if that is the case, he again becomes active on the forum. I think any disagreements were meant to be respectful and constructive.
David,DLB wrote: ↑Fri Dec 31, 2021 8:02 pm Note: RFGuy has been silent recently on the forum. I hope that everything is okay. I sensed that he might have been perturbed with the direction another thread went. I hope, if that is the case, he again becomes active on the forum. I think any disagreements were meant to be respectful and constructive.
Thanks. I am still alive and kicking. I was certainly surprised by the direction a few threads took last year, but no that is not why I left the forum. I wasn't feeling very fulfilled in participating online last year, so I curtailed all of my social media and have been much happier as a result of it. There are lots of experts on this forum, so my meager contributions probably won't be missed. I still pop in from time to time to check on any threads that interest me, but I do it a lot less often now.
P.S. Happy New Year!
RF Guy
Thank you for that update, I'm glad to hear you are doing well. For the record - I understand but I'll miss your contributions.RFGuy wrote: ↑Sun Jan 02, 2022 6:22 amDavid,DLB wrote: ↑Fri Dec 31, 2021 8:02 pm Note: RFGuy has been silent recently on the forum. I hope that everything is okay. I sensed that he might have been perturbed with the direction another thread went. I hope, if that is the case, he again becomes active on the forum. I think any disagreements were meant to be respectful and constructive.
I agree with David, I will definitely miss your contributions. I had to give up all the social media sites several years ago and my mental life is much happier.DLB wrote: ↑Sun Jan 02, 2022 9:33 amThank you for that update, I'm glad to hear you are doing well. For the record - I understand but I'll miss your contributions.RFGuy wrote: ↑Sun Jan 02, 2022 6:22 amDavid,DLB wrote: ↑Fri Dec 31, 2021 8:02 pm Note: RFGuy has been silent recently on the forum. I hope that everything is okay. I sensed that he might have been perturbed with the direction another thread went. I hope, if that is the case, he again becomes active on the forum. I think any disagreements were meant to be respectful and constructive.
Happy New Year to you too.
Marc Jones
So does this indicate ignorance(of social media gossip etc.) is bliss? ;>}
I believe so. And maybe bliss is the attainment and maintenance of your ignorance.
Marc Jones
Keep in mind that this forum IS a form of social media. Thanks to David and Marc for your kind words. It is appreciated and I will miss conversing with you. To those in the peanut gallery, I say sayonara.
RF Guy
- Silver Member
Hello,
I just wanted to give my opinion which seems different than most.
My DC3000 was over 20 years old. I performed the upgrade and am happy I did. My dust collector works better and quieter. I feel like it gave me a new dust collector for half the price of purchasing new.
I did, however, run into one problem. After about 2 months of use, the starter capacitor adhesive mounting tape came loose, the capacitor dangled, and one of it's leads came out of the crimp terminal. Shopsmith replaced the capacitor at no charge. This time, I installed the capacitor with a 1-1/2" diameter clamp and am not relying on the adhesive mounting tape. See photos attached.
