SS Panel Clamps
SS Panel Clamps
I have the opportunity to purchase 4 - 36" SS Panel Clamps for $75.00. Is that a good deal? Do these clamps even work as advertised? I have several panels I need to make in a project this spring. What's everyone's thoughts?
Kevin Collins
1x Mark 7 - 520
2x Mark 5 - 510
1x 1956 Mark 5 - 500 in need of restoration
1x Mark 7 - 520
2x Mark 5 - 510
Re: SS Panel Clamps
I'd take that deal if they are in good condition. I have 3 of the 36" length and have used them on some big glue ups, including a few weeks ago for a very large end grain cutting board. They work very well once you learn a few tricks (like take off the top caul while you set your strips in place and get them glued).
- BuckeyeDennis
Re: SS Panel Clamps
That's a great deal. I have three of them, and they do work as advertised.
Woodpeckers is currently running a special on their version of that design. $600 for four of them, on sale. And they don't have the curved cauls like the Shopsmith clamps. And you have to wait six months to get them.
https://www.woodpeck.com/clampzilla-3.html
As Al notes, getting the boards into place within the panel clamps can be fussy, because the clamp springs want to keep them closed. Nick Engler did a video some time back; IIRC he was using the panel clamps to create a veneer press. In any case, he used a technique that I've been meaning to try. He basically just cut some small spacer blocks, and before loading in the workpiece boards, he placed a spacer just inside in each end of each panel clamp. The spacers hold the cauls apart while loading, and then you remove them after the workpiece boards are all in place.
Re: SS Panel Clamps
Cool thanks guys...
Kevin Collins
1x Mark 7 - 520
2x Mark 5 - 510
1x Mark 7 - 520
2x Mark 5 - 510
Re: SS Panel Clamps
Also, while Shopsmith still sells them, they changed the hardware. I have no idea if it works as well, but it definitely does not look as cool as the old hardware which looked exactly like the big aluminum "wing nut" used on the Shopsmith head stock lock, depth stop lock and quill lock.
Re: SS Panel Clamps
That's what these have.algale wrote: ↑Tue Jan 04, 2022 4:09 pm Also, while Shopsmith still sells them, they changed the hardware. I have no idea if it works as well, but it definitely does not look as cool as the old hardware which looked exactly like the big aluminum "wing nut" used on the Shopsmith head stock lock, depth stop lock and quill lock.
Kevin Collins
1x Mark 7 - 520
2x Mark 5 - 510
1x Mark 7 - 520
2x Mark 5 - 510
Re: SS Panel Clamps
I'd buy them for sure! I wish I had bought 4 rather than 3 when I did. Dang I'm jealous, lol.
Btw, Shopsmith will now sell you just the wood cauls.
Re: SS Panel Clamps
Well I bought them. They are straight and in really good shape.
Kevin Collins
1x Mark 7 - 520
2x Mark 5 - 510
1x Mark 7 - 520
2x Mark 5 - 510
Re: SS Panel Clamps
I'm going to try them out tonight at a community education woodworking class.
Kevin Collins
1x Mark 7 - 520
2x Mark 5 - 510
1x Mark 7 - 520
2x Mark 5 - 510
Re: SS Panel Clamps
Wax the heck out of the wood surfaces/faces. That way any glue drips will flick right off.
