Idler Shaft Assembly
bainin
Post by bainin »
On hold on the SS hotline ...so I figured I'd try to get the answer here while waiting.
I want to get a backup Idler assembly for my DIY PowerPro tool. This linked
item seems like what I want, and I do have the newer "split" eccentric shown in that service notice.
https://www.shopsmith.com/ownersite/ite ... tem=522741
So - with this item, I assume I get the shaft (lol!) , and mounted bearings?
Anyone know?
thanks !
b
Re: Idler Shaft Assembly
bainin wrote: Fri Jan 14, 2022 2:02 pm On hold on the SS hotline ...so I figured I'd try to get the answer here while waiting.
Anyone know?
thanks !
b
Yes, that part number includes the shaft and bearings. If you want the eccentric, that is a separate line item.
bainin
Post by bainin »
Thanks Dusty.
b
DLB
Post by DLB »
My internet connection is down so please double check this. I have a new PP Idler, PN is on the bag but not completely legible. Also not 522741. I think that PN is for the conventional headstock. My PP DIY book lists the Idler as 522612. That looks like a probable match for the bag I have.
DLB wrote: Sat Jan 15, 2022 8:45 am My internet connection is down so please double check this. I have a new PP Idler, PN is on the bag but not completely legible. Also not 522741. I think that PN is for the conventional headstock. My PP DIY book lists the Idler as 522612. That looks like a probable match for the bag I have.
+1 !!!
No way to verify on website: no M7 headstock parts/drawings.!
bainin
Post by bainin »
Thanks again -
I will go with the 522612 and see what i get !
b
bainin wrote: Sat Jan 15, 2022 12:27 pm Thanks again -
b
If you have the PowerPro headstock that is probably what you need. The number that I gave is definitely not for the PowerPro. Sorry about that.
Do you have the manual that came with your DIY PowerPro Upgrade kit?
522612 is the correct one or the Power Pro.
https://www.shopsmith.com/ownersite/ite ... tem=522612
My Mark 7 manual lists part number 522612 as the Idler Shaft Assembly. It is different than the Idler Shaft Assembly for the conventional headstock currently P/N 522741. On the website it is P/N 522612 PowerPro Idler Shaft Assembly at the link below.
All SPT's & 2 Power Stations
