Headstock Lock
russearline
Headstock Lock
Post by russearline »
My headstock lock is really hard to turn and it doesn't secure the headstock to the way tubes. Troubleshooting gude said to adjust the lock, however I can't find anything in the manual about adjusting it. Any sugestions will be greatly appreciated.
billmayo
Headstock Lock
Post by billmayo »
russearline wrote:My headstock lock is really hard to turn and it doesn't secure the headstock to the way tubes. Troubleshooting gude said to adjust the lock, however I can't find anything in the manual about adjusting it. Any sugestions will be greatly appreciated.
This one gets you to the 25 Shopsmith maintenance procedures:
http://www.allinonewood.com/?page=shop/serviceadvisor
18. How to Replace the Headstock Lock (157kb)
I would recommend coping all 25 maintenance procedures to your computer and to a CD for future use.
It sounds as if you will need to replace the wedges and rod as it sounds like someone over tighten the headstock lock.
billmayo
Headstock Lock
Post by billmayo »
russearline
Headstock Lock
Thanks Bill that info was very helpful. I'm going to see if I an fix it up enough to use it until I can order a new one.
Gene Howe
Wait!
Post by Gene Howe »
:eek:
Don't order the lock until you've examined at the present one. Your symptoms mirrored mine. Follow the procedure for replacing the lock and you may find it's simply not adjusted correctly, as I did. In which case, it's an extremely simple fix.
Gene
Gene
25 Procedures
billmayo wrote:This one gets you to the 25 Shopsmith maintenance procedures:
Thank You Bill .. Any known inaccuracies???:confused: :)
P.S. Gene's advice is good for ANY problem!
