Getting Ready for Grilling
bainin
Post by bainin »
Well- I've lived with this problem too long.
My grill is a cheap POS..but it actually makes a nice burger or steak.
The one issue - when i get to the grill- there is NO place to set anything down. Well- except the ground. Which is fine, except for the neighbors dogs , who for some reason, seem to be let out just as soon as I put a plate of raw meat on the ground.
So- i needed to come up with something to keep my plate off the ground and here it is .
It registers against the existing handle on the grill .
The rod slips into/out of the block for easy removal. You know- when it catches on fire :)
Im thinking I want to cut a curve into it to form fit a bit better the the grill cover shape..but maybe another day.
garys
Re: Getting Ready for Grilling
Post by garys »
I have something like this. It isn't fancy, but it serves my needs. The only reason mine is this big is because in addition to using it for grilling, I also need it to smoke my homemade sausages and bacon. I make summer sausages that are around 20" long so I need to fit them into the grille, and this size does that job.
https://www.chargriller.com/collections ... s/superpro#
Your grille does the grilling just as well as a larger one, and you solved the problem of having a "parking" place for the tools and meat. Good thinking.
Nice job on a table for the Kettle style Grill. I always found not having table space to be an inconvenience too. Since we weren't using it I gave my Webber away a few years ago after replacing the wood on the handle for the cover. Of course, I made a replacement handle using my Shopsmith tools. :)
garys
Post by garys »
I ended up replacing the wood handle on my grille too. The original one was cracked from end to end due to moisture getting into it. I found a decent piece of hickory wood in my wood pile and made this.
Hobbyman2
Post by Hobbyman2 »
Nice job !!
