SHOP NOTES:
There are so many interesting projects that need precise circles, such as tabletops, toy wheels, decorative items, and functional items such as these hurricane lantern candle bases. This simple, fast and safe process is as easy as 1, 2, 3, 4, repeat.
Mark the center location and draw a circle with a compass. Don't skip this step by tracing a circle from another round object, because you'll need that center location in step three.
Cut the circle slightly oversized on the bandsaw.
Drill your center location with a hole that will accommodate your pivot point. I used a 5mm dowl because that's what I had on hand, but you can pivot on any size dowel or pin as long as the hole doesn't cause problems with your project. If your circles are wheels for a toy, use a hole that will later match your axel size, for example.
Use your Mark V's sanding disc to sand the wooden discs to the exact size, pivoting on a pivot installed on a piece of scrap clamped to the main table. I typically make the first one very carefully and set the depth stop for all successive discs.
Please consider joining the 100+ other channel members in supporting the channel and get access to perks:
https://www.youtube.com/c/MyGrowthRings/featured
Here's an idea: If you aren't ready or able to join the channel, you can always support the channel by watching, clicking the thumbs-up, commenting, sharing, and by clicking through the provided links whenever you are shopping on Amazon or eBay. You don't even need to purchase the items these links lead to, but by going through these links they'll reward us with a small "finders fee". Thanks in advance for the support!
I've created an Amazon list of many of the tools that I have found to be indispensable in my shop.
http://a.co/0GLhuR2 You may have to click the "Filter" link to show the items in the list. I suggest sorting them by priority.
Products used in this video (in no particular order):
Here's my preferred abrasive cleaning stick:
https://amzn.to/3loB0UB The one I found at Harbor Freight was a disappointment.
Timber Wolf 1/2" x 72" 4 TPI bandsaw blade for the Shopsmith bandsaw:
https://amzn.to/34ShtU5 I LOVE this blade!
My favorite 9" long T-handle "Shopsmith Toolbox" 5/32" Hex Wrench:
https://amzn.to/3sm3NcJ
If you are need of an assortment of 12" sanding discs, give these a try:
https://amzn.to/3fl3Dy3 or this set if you need crazy-fine discs for sharpening:
https://amzn.to/3nm3NJT
Visit
http://www.MyGrowthRings.com
Follow on Instagram @MyGrowthRings
I also blog at
http://www.tool-hunter.com/shopsmith-posts and
http://shopsmith-tool-hunter.blogspot.com/
DISCLAIMER:
A few viewers have requested I provide affiliate links to help them find the products I use and as a way of supporting the channel through commission. If you purchase a product or service with the links I provide, there is no additional charge to you. As an Amazon Associate and an eBay affiliate, I may earn a commission from qualifying purchases. I always recommend shopping around for a better price. Thank you for supporting My Growth Rings!
#Shospmith #ShopsmithBandsaw #CuttingCircles
