Russ:
I think that's a good lesson for me to leave unrusted areas well enough alone. Good luck with your move, may the summer weather be kind.
4E Magna jointer as an SPT standalone - possible?
Re: 4E Magna jointer as an SPT standalone - possible?
Scott E.
Scott E.
In the event it becomes "necessary" to loosen the screws, use a harbor freight hammer operated impact wrench/screwdriver.
https://www.harborfreight.com/6-bit-imp ... 64812.html
In my last post I was only referring to Jointers I have worked on. I have had stubborn fence screws on Model 10 restorations for the table fence bars and have used an impact screwdriver similar to the one JPG suggested with success. It can give that extra needed start to loosening the screws. Do use a blade size that fits snug in the screw's slot for best results.
All SPT's & 2 Power Stations
And hold straight tightly and preload the rotation.chapmanruss wrote: ↑Sun Jul 09, 2023 11:28 am In my last post I was only referring to Jointers I have worked on. I have had stubborn fence screws on Model 10 restorations for the table fence bars and have used an impact screwdriver similar to the one JPG suggested with success. It can give that extra needed start to loosening the screws. Do use a blade size that fits snug in the screw's slot for best results.
Takes some practice.
What helps it work is the force supplied by the hammer pushes against an internal cam that then pushed both towards the screw AND simultaneously rotates.
JPG said...
"And hold straight tightly and preload the rotation."
That makes all the difference in the world.
