Just do yourself a favor and use saw tooth hangers. One in the middle will hold many pounds with two small screws and your through...
Putting a cable attached on each side is not needed for 95% of all the frames you will ever build.
When you are building a frame either for stained glass or pictures
- Bronze Member
Re: When you are building a frame either for stained glass or pictures
? ? ?calculatewally wrote: ↑Sun May 29, 2022 9:39 pm It is possible to support a significant amount of weight using nothing more than two screws and your way through it... In ninety-five percent of the frames you will ever make, adding a cable will be completely unnecessaryplay tic tac toe
There's a semi-hidden link at the end that says "play tic tac toe" at the end (white text struck through). I've reported it as link spam
Greenie SN 362819 (upgraded to 510), Bandsaw 106878, Jointer SS16466
