Removing Sand Paper from Disc Sander
Just getting back into using my Mark V.....I have some sand paper which has been adhered to my disc sander for the past 5 or 6 years. The paper has become brittle and I can't remove it very easily. Any suggestions on how to remove old sander paper from my Mark V Disc Sander? Thanks......Paul
Remove sandpaper
I have been told to either put the disk in the freezer for a couple of hours or gently warm it up in the oven at a low temperature for half hour. The freezer will make the adhesive brittle or using the oven will soften the adhesive up.
Jim in Tucson
Jim in Tucson
Removing PSA sandpaper from disk
Hey Piccut and other Forum members!
PSA sandpaper = pressure sensitive adhesive. An easy way is to use the bath tub, put enough HOT water almost up to the set screw in shaft of the disk and leave the disk in the hot water for about 15 minutes. A laundry tub is not sufficient as the water will cool down too quick. Remove the disk from the water and begin pulling the paper off. What residue is left behind can be tacked off with the removed paper, similar to rubber cement attaching to itself. Use mineral spirits to clean any excess off. Better than the oven method as you can handle the disk without gloves.
NOTE: Clean the bath tub so the "significant other" does not know what you have done.
Another method is to use a hair dryer and heat the disk. This method is better than the oven method. Handling the disk while it's warm coming from the oven is a little clumsy with the gloves. Don't forget to return the hair dryer to it's original location.
I use both of these methods with success.
Life is a chip at a time,
Spike13
Spike13
In the dead of winter once I found that applying heat from a propane torch to the back side of the sander allowed me to peal off the sticky sandpaper very easily. It really didn't take much heat so I wasn't worried about warping the disc - after that I cleaned it up with some lacquer thinner and went over it with a fine grit sandpaper to smooth it out then stuck on the next sandpaper disc. Still workd like a charm. I'm sure the oven method works well too, but my way was done on the machine with little chance of burning yourself or making my wife mad.
Andy
andy@manvell.org
andy@manvell.org
Re: Removing Sand Paper from Disc Sander
I have just the opposite problem.
Shopsmith offered a real good sale on sand paper (disks and belts) a long while back. Being frugal as I am, I bought up a bunch which has now turned out to have not been frugal at all. I have a shelf full of adhesive backed sanding disks with adhesive that is no longer sticky.
I am too frugal to discard it so I cut it in pieces and use it for hand sanding.
