Non-SS Recommendation
db5
Post by db5 »
I have a Weller 8000N soldering gun with copper tips and need replacements. The stuff available seems to be crap. I know some people use Romex copper wire. Your thoughts?
Re: Non-SS Recommendation
My Weller Soldering Gun is the Model 7200 and the tips insert differently, screw clamping as opposed to the hex nuts many of them use. I did a search (weller soldering gun tips) and found some available. Some were pretty cheap looking not having the heavy point. Those looked like they were made out of copper wire. I also found a couple of you-tube videos about making your own out of copper wire. Probably the same videos you found. I know I would prefer to have the standard soldering gun tips with the heavy end like the ones in the picture below. It may take some looking around to find the right ones for your Soldering Gun.
_
Hobbyman2
Post by Hobbyman2 »
I located these on ebay you could also try Amazon https://www.ebay.com/itm/275377527498?e ... BMzInW881g
JMO ,,, romex may be a little too soft and bend on ya when it heats up , try it and see ?
A Lot on Amazon. Both straight attaching end and angled attaching end with hex nuts.
db5
Post by db5 »
Thank you all. Or as they said when I lived in Texas, "all y'all".
garys
Post by garys »
A friend in Oklahoma once told me that "y'all" is the singular and "all y'all" is the plural of the pronoun.
Any one care to explain "youse"?
edma194
Post by edma194 »
The use of "y'all" for a single person is debated, except for an equivalent ambiguous usage of "you". After all, it's short for "you all", which is something said to multiple people.
"youse" is basically the same, generally applied to multiple people, but sometimes it's used for individuals.
When growing up in Tennessee, “y’all” was consistently and unequivocally used as second-person plural. But despite once having neighbors who used the term, I never did quite figure out “you’ins”.
There are we'uns and you'uns.
Sorta like us vs youse.
