What kind of wood is this?
rlkeeney
Post by rlkeeney »
Would you guess what kind of wood this is?
This is hardwood flooring. It's old, heavy, and hard. Used 80-grit sandpaper will barely scratch it.
This is a slice off the end of the only used and darkest piece.
2022-08-20 20.35.49.jpg (255.88 KiB) Viewed 2150 times
The same piece with a little mineral oil on it.
2022-08-20 20.38.12.jpg (284.33 KiB) Viewed 2150 times
The face of one of the lighter boards.
2022-08-20 20.43.12.jpg (215.54 KiB) Viewed 2150 times
Robert Keeney
Tallahassee Florida USA
Re: What kind of wood is this?
SteveMaryland
Post by SteveMaryland »
Saw on it a little bit and smell. If it smells sweet it might be rosewood. If no smell, might be locust.
If you drop it on concrete and it has a clangy sound, might be rosewood.
BillVan
Post by BillVan »
Wenge maybe? It looks like a piece that I have
Hobbyman2
Post by Hobbyman2 »
rlkeeney
Post by rlkeeney »
Black Locust - It sure does look like the photos in the Wood Database
Wenge - I don't think this would be a match. The end grain looks different.
Katalox - I only have one dark board. I'm guessing heartwood. The end grain is different.
Rosewood - I don't notice any smell when I cut it, and it does not ring when dropped or struck.
Black Locust is the closest match.
Robert Keeney
daveg
Post by daveg »
Just a guess, Brazilian Walnut (Ipe)?
rlkeeney
Post by rlkeeney »
daveg wrote: Sun Aug 28, 2022 1:57 am Just a guess, Brazilian Walnut (Ipe)?
I think you are correct.
Robert Keeney
Hobbyman2
Post by Hobbyman2 »
Years , well ,, decades ago we used a lot of Brazilian lumber , my job was sanding , and sanding , and sanding ,, JMO I could be wrong ,, but it looks a little bit oily to be BW ?
toolcurve
Post by toolcurve »
It does look to be BW, what is the weight, does it seem more dense / heavy then normal hardwood?
