Just Joined
whitefox
Just Joined
Post by whitefox »
I purchased a SHopSmith MK 5 a year or so ago, and am just now able to use it as I have a better space for it. So far I really like it, got the Band saw along with and have added a few acc. along the way. THe fellow I boought it from had a whole case full of the magazine, so I have been doing a lot of reading. I have used mostly the table saw, drill press, and band saw, but want to start using the lathe next. I need to make end pieces for a round flute case. The barrel is PVC pipe. I plan on making it flat on one end, and rounded at tghe other, and will cut off a slab to screw into the bottom end. I need to make this pretty prescice as the top will just be friction fitted. I may also attach a few ties to cross tie the top for security.
I look forward to talking with others about this really nice tool.
Just bought a used Mark V and love it.:)
mickyd
Post by mickyd »
Welcome whitefox. There's plenty of info in this forum for you to sink your teeth into. Your questions will be answered, I gaurantee. There are lots of knowledgeable folks in here that are more than willing to help you out.
Sunny San Diego
curiousgeorge
Post by curiousgeorge »
Hello, whitefox. Welcome to the forum. You have come to the right place to talk and learn about the MK V.
George
Ft. Worth, TX.
Go TCU Froggies
a1gutterman
Post by a1gutterman »
Welcome whitefox!
Thanks for joining us. Do you mind going back to your public profile and putting down some additional info, like your general location?
Tim
beeg
Post by beeg »
Welcome to ShopSmith land WhiteFox. Browse around here, there's plenty to learn. Any questions just ask.
etc92guy
Post by etc92guy »
Glad you decided to join this forum, whitefox. I lurked here for about two weeks before committing to buying my Mark V. This forum and the people that contribute to it were THE deciding factor.
And since October, I have developed 2 friendships because of this forum. An unexpected plus.
8iowa
Post by 8iowa »
For lathe work, I'll suggest getting the "live" center (505602). This is a big improvement over the dead center that comes with the Shopsmith.
jbooher
Post by jbooher »
Be sure and check out the Sawdust sessions. There is a lot of useful information on cleaning and using your SS.
James
beeg
Post by beeg »
JUST a thought, but you could make the PVC end pieces larger that the pipe. Then cut a groove in it to fit the PVC pipe.
wlhayesmfs
Post by wlhayesmfs »
Welcome to the Group, I have learned a lot here and hope it helps you also.
Bill :)
Broken Arrow OK
