Mark 4 way and bench tube length
I want convert my 510 to a mark 4, my new shop has a low ceiling so I can't put it in drill press mode. So I thought that converting it to a Mark 4 would solve the problem. Anyone know the Mark 4 tubes lengths?
Re: Mark 4 way and bench tube length
Personally I prefer a shorty (Mark 4) but that is as a second machine. If I was trying to address a low ceiling problem I would shorten by only the amount needed for clearance in order to maintain as much of the original capability as practical. Bench tubes are a bit (~ 3/4") longer than way tubes on a standard machine. If you are cutting your tubes you want to maintain that difference by cutting the same amount off of all tubes. IMO that 3/4" difference is not ideal for a Double Tilt (DT) machine, which includes the Mark 4's, but I don't know if SS has changed it. My understanding is that the Mark 4 is 16" shorter than 'standard.' That's about the same as mine, and is about the shortest practical length for a full featured machine.
The way tubes for a full size machine with double tilt end up a little short by about 3/8". This means in drill press mode the way tubes are not sitting all the way into one end casting or the other. That means the weight on the way tubes is held up only by the set screws and conceivably could the tubes can slip down in the casting although I think it's unlikely because the weight is distributed across all 4 set screws. I am wondering if there's a reason to keep the way tubes short like that other than avoiding production of new way tubes to a different length. If there's no reason for them to be short I would prefer having them full length in a shorty.
As David pointed out you can't cut off more that 16" without getting too tight for practical usage.. You need room for the carriage and the headstock, and a minimum amount of space for the table even if it hangs over end, and to be able to move the headstock and table in order to mount tools and couplers.
So that implies 3/8" longer bench tubes rather than 3/4".(with double tilt)
Or use 3/16" spacers on each end of both of the way tubes
I went with the shorter bench tubes on my shorty when I added DT. I had to cut new tubes anyway because it started life as my Grandfather-in-law's Greenie so the bench tubes would no longer fit. (Not much of that DMA left after numerous upgrades.)
I have not addressed this on my 520 upgraded to M7. I'm leaning toward the spacers. I've never had an issue with the setscrews holding, but it bugs me knowing those bench tubes aren't seated at either end.
I looked on the SS web site and could not find a listing to buy the mark 4 tubes. So I figured I would need to cut mine tubes. I think cutting them 15” shorter will be a safe start. And give me enough room to set it up in drill press mode.
I thought I saw recently that Shopsmith was selling different length waytubes/bench tubes. Perhaps it was in one of the weekly sales flyers, but I can't remember. IF interested in buying them precut, you might have to call them to confirm. The website doesn't always have detailed descriptions or even pictures for certain items like this.
RF Guy
I wasn't concerned with this at all until I made my own double tilt shorty out of a pair of right side hinged castings. I made this specifically for refurbing headstocks so I'll be removing one end of the base or the other frequently to mount and dismount headstocks. When remounting the hinged based piece I'd like it have it go to a fixed position. At the moment I don't lock the casting to the tubes until it's back in the horizontal position. I started by cutting a way tube and a bench tube in half, knowing that would leave the way tubes too short. I can cut the bench tubes down further to get the length just right but I think a spacer is a better approach. Just some marks on the way tubes works pretty well already. I'll create a thread for this interesting project soon,
