All
My new used shopsmith came with a all purpose blade and a 1 1/4 saw arbor.
Upon inspection of the arbor somone gauled it up and had for some reason tried to drill out the set screw and buggered the hole and threads all up.
Well tonight I finished drilling out and removing the set screw and then drilled the hole oversize to clean things up.
Does anybody see a safety reason with tapping the oversized hole and useing a bigger set screw to make the arbor useable again?
I have to purchase a tap and set screw but it should save the arbor from the trash can.
Wholeshoe
1 1/4 Saw Arbor Repair
The set screw in the arbor should be a Shopsmith item as it is softer than a normal set screw. A normal set screw (harder) will damage the quill shaft over time. I believe a tap and set screw will cost more than another used 1 1/4" saw arbor that are quite available. I trash any used arbors that shows any signs of damage just to be safe.wholeshoe wrote:All
Wholeshoe
Bill...billmayo wrote:The set screw in the arbor should be a Shopsmith item as it is softer than a normal set screw. A normal set screw (harder) will damage the quill shaft over time. I believe a tap and set screw will cost more than another used 1 1/4" saw arbor that are quite available. I trash any used arbors that shows any signs of damage just to be safe.
Thanks good to know. I've replaced several SS set screws with after market stainless. I guess I'll be switching back.
Art...
You could drill and tape a new hole 180 degrees from the original. I can't imagine that it would alter the strength of the shaft itself.
Dave - Idaho
"Why do we drive on parkways and park on driveways?"
