Accessory Shelf
putttn
Accessory Shelf
Post by putttn »
Can the accessory board be mounted on the SS's legs at different heights or just one height. I thought I'd seen it at a couple of different locations.
putttn wrote:Can the accessory board be mounted on the SS's legs at different heights or just one height. I thought I'd seen it at a couple of different locations.
As built, the older shelf can only be mounted at one predetermined level because of the location of predrilled holes and cut outs.
The same shelf could certainly be mounted at a different location by making some physical changes either to the shelf or to the legs of the Shopsmith (hole locations).
If I was contemplating that, I'd just make my own. Why, so that I could put my accessories where I want them not where someone else made a place for them. As a woodworker, you have all the tools and skills to do this.
