I would be concerned that "the manual" may be different in different versions.DLB wrote: ↑Sun Jan 14, 2024 4:46 pmI think SS needs to take a harder look at this. 501439 (Ref No. 291) is in the manual as a tube collar with no setscrew. 501438, confirmed by Alan earlier as a collar with setscrew, is in the manual as item 290, "Tailstock & Tube Asm." In other words a Tailstock (if we're still using that word ) without stop collars. I didn't see any way to 'find' a stop collar on the web site except by searching that text. In other words the PL and Exploded View, as it pertains to the Tailstock, isn't on the web site but it is in the manual. (I think I should find it under service parts.)admin wrote: ↑Sun Jan 14, 2024 8:15 am Please contact Customer Service on Monday. 501439 (stop collar without the set screw) should not have been on the website and has now been removed. It appears we missed that when setting up the new website.
To those that noticed, yes items not intended to be available may have strange pricing since we don't update those.
Admin
The only thing that I see here that is consistent with the manual is that I should be able to order Item 291, PH 501439, as a collar without setscrew. Taking it off the web site would leave one (that was using the manual) thinking it can only be ordered from SS as part of a complete tailstock. Thence to eBay, where new stop collars are sold by competitors. Or somewhere else where less expensive versions that don't support the 5/32" hex key are more prevalent.
Stop Collars - the accessory I should have bought years ago
Re: Stop Collars - the accessory I should have bought years ago
True. I submit that there are multiple solutions that are better than eliminating 501439 from the web site. (Now returns "Nothing found.") If a part in the manual is superseded, it is much better if a search returns that information.
I also don't see anything wrong with making both versions available, I was about to buy a handful of 501439 on my next order based on information in this thread and the manual. I wouldn't normally buy 501438 because the description on the web site conflicts with my manual and the description on the web site is inadequate to tell me what I'm buying (size of stop collar is not included, though algale, above, confirms that this is a complete stop collar and of the correct size for this intended purpose.) Also, I generally try to buy OEM but recent pricing chases have caused me to rethink this. And of the two, only 501439 is priced competitively.
My 'experience' with 3rd party stop collars is that they are a looser fit. Very small sample size!!!! Also the set screws are cupoint.
Has anyone tried clamping stop collars? I assume they can account for minor discrepancies in diameter, but perhaps I'm mistaken about that.
I would prefer the split collar type.
Correct me if I am wrong, but there is only one size (ID) stop collar. All the tubes you would normally use one on are the same size.DLB wrote: ↑Mon Jan 15, 2024 10:56 amTrue. I submit that there are multiple solutions that are better than eliminating 501439 from the web site. (Now returns "Nothing found.") If a part in the manual is superseded, it is much better if a search returns that information.
Skip Campbell has used them on the Model 10. I don't see any reason why they would not work on a MK V/5. I have a big one on vertical column of my stand alone pin router. They have the added benefit of no set screw marks and they can be put on a tube anywhere. You don't have to slip them over the end which might require removing a component to get the collar in the right position.
- SteveMaryland
Yes, the 2-piece split collar is the best, for the reasons Mr. Burger cited. I would much rather have them than the setscrew type. Much larger and more reliable holding force than setscrew also.
I looked at McMaster, their lowest price 2-piece metal collar (for 1-1/4" ID) is $14.44 each. All others, including in aluminum, are more.
And the screw is a .250-28, which would have a 3/16" hex hole, larger than the 5/32" "Shopsmith Toolkit". Oh well.
An example of a low cost collar from Amazon available for $9.89. It has a 1/4x28 'setscrew', a cap screw really, which usually has a 3/16" hex drive. A 5/32"drive would be nicer but a lot of stop collars don't get moved much over their lifetime so drive size doesn't matter that much for them.
Expanding your sample size slightly, I compared a Tractor Supply (Labeled County Line brand) off the shelf collar to the OEM. These are larger in every way compared to OEM, including a slightly looser fit. I measured ID using two slide calipers, one digital and one dial, and the SS version measured 1.248" on both while the other measured 1.252" on both. A single sample of a main table leg (DT version) measures slightly smaller than I expected at 1.240". Subjectively, placing the collars on the leg with the setscrew loose, the SS version is a better fit. When tightened down and used as intended, either version seems to work fine.
