Now he tells me.
520/Pro Fence lock adjustments
Re: 520/Pro Fence lock adjustments
- BuckeyeDennis
Al, IIRC denatured alcohol cleans up graphite nicely.
- SteveMaryland
Brenda recently viewtopic.php?p=299309#p299309 advised using alcohol as a solvent for dry graphite. This allows the graphite to be applied as a liquid rather than as a dry dust.
I avoided graphite powder lube because of the mess and application difficulty. Then I tried Brenda's idea. Big improvement. My method is to syringe-inject the alcohol directly into the plastic squeeze tube that the graphite comes in, and then shake the tube before every application.
Now I never have to handle the graphite directly, and I can put graphite exactly where I want it, and no more graphite dust everywhere. The alcohol evaporates and leaves a dry graphite film. Great for wherever we don't want exposed oil.
I have a can of Boeshield. Rave reviews for it online, but it is really expensive and I don't know that it leaves any lube when dry, or is any better than WD-40.
Thanks Brenda, and Merry Christmas to all!
I was using a PB Blaster brand aerosol. More of grenade type weapon than a precision sniper rifle. Thanks for the tips on removal. Denatured alcohol and some "elbow grease" got rid of the excess film. My fence is all tuned up. Even managed to horizontal bore a 3/4" forstner bit into end grain with no fence movement w/o backing up the fence. (Although I did have the main table tied into the extension table with the 520 extension tubes).
