First Project - Storage Cabinet
Irmaplotz
Post by Irmaplotz »
After lurking around here for a really long-time and learning so much from the forums about how to set up and use my SS, I thought I'd share the results. My first build (other than a few safety jigs) is an understorage cabinet inspired by onetrack's build from several years back. viewtopic.php?t=15776
Under storage cabinet.jpg (289.17 KiB) Viewed 209006 times
I'm going to wait until spring to put any finish on it. I may just throw some poly on it and call it done.
Before foam.jpg (358.88 KiB) Viewed 209006 times
It does have full extension drawer slides which were very fiddly, but are now working well. I put in some foam to line the drawers and keep everything from rattling around when I wheel it out. Even with the foam it holds a surprising amount of stuff.
Inside top drawer.jpg (300.86 KiB) Viewed 209006 times
Inside bottom drawer.jpg (179.12 KiB) Viewed 209006 times
It's not completely perfect, but I'm happy with how it turned out and all of the storage space its freed up in the rest of our garage!
algale
Re: First Project - Storage Cabinet
Post by algale »
Very nice job!
Looks really great.
edflorence
Post by edflorence »
Very nice! All that storage will prove quite handy.
Idaho Panhandle
Matanuska
Post by Matanuska »
Nice. What will you keep in the storage bays on each side?
- Matanuska
1984 Mark V upgraded to 520 PowerPro. Shopsmith cast iron table bandsaw, jointer, belt sander, and 60's vintage 610 jigsaw SPT's. Makita 2040 15" planer, JessEm Mast-R-Lift II router table.
12" sanding discs.
Manuals.
Tall stuff.
edma194
Post by edma194 »
I like it. The tall bays on the sides should be useful. No need to take up most of a drawer to hold a saw guard or a tail stock.
Irmaplotz,
Even though you have been a member for a while Welcome to the Forum and thank you for sharing your project in your first post. Nice work. I am sure you will find the cabinet very useful. As you start organizing it you may find little tweaks or small changes to make it more user friendly for holding accessories. If you do, please add updates. Again, nice project.
twistsol
Post by twistsol »
That is a heck oof a first project; nicely done!
Thanks much,
Chris Phelps
Cheap tools are too expensive
2x Mark 5 520 and a 10ER
Irmaplotz
Post by Irmaplotz »
JPG wrote: Fri Jan 05, 2024 8:36 am 12" sanding discs.
Manuals.
Tall stuff.
Yes! Exactly. That sanding disk and the sandpaper was taking up so much space! It's nice to have a place for that and the manual.
