Cross cut sled
Cross cut sled
I am going to build a sled like the one Shopsmith sells. They mention it will easily set certain angles. How is this done? The only picture I can find of it shows nothing that would give a clue.The Rockler sled has a built in protractor scale and a moveable fence to do angles for example.
SS 520, SS band saw. Grizzly cabinet saw, jointer, drill press,14" bandsaw, belt/disc sander. Delta 13" planer. Hitachi router in router table. Old Craftsman radial arm saw.
Re: Cross cut sled
There are stops.
Re: Cross cut sled
Do you mean what SS calls a Cross-cut Sliding Table? If yes, the laminate portion has pre-drilled holes for mounting the aluminum fence at the listed angles. I don't use this feature, it took me a minute to get it accurate at 90 degrees and I'd be reluctant to disturb that.oso2you wrote: ↑Thu Jan 25, 2024 2:00 am I am going to build a sled like the one Shopsmith sells. They mention it will easily set certain angles. How is this done? The only picture I can find of it shows nothing that would give a clue.The Rockler sled has a built in protractor scale and a moveable fence to do angles for example.
Re: Cross cut sled
I made my own using the "T" Track bar Shopsmith sells. Like David I keep mine set at 90 degrees. I haven't had a need to cut other angles that I couldn't do in a better way than with the Cross-Cut Sliding Table I made. I prefer using the Miter with an extension fence, if needed, on my Shopsmith or my Compound Miter Saw or my Radial Arm Saw.
All SPT's & 2 Power Stations
Re: Cross cut sled
I think I am better off just leaving it at 90 deg. The more movable parts I have, the greater the chance for less accuracy down the line.
Re: Cross cut sled
I think that's a good call. There is a good reason that people use the five cut method to square a sled or sliding table. With a miter gauge you can directly measure or set the critical angle but with a sliding table/sled you can't do that directly. If I was making a sled for angled cuts I'd model it after the Incra 5000. Or buy an Incra 5000 and put a SS miter bar on it.(?) Pricey but they seem to have gotten it right. For more than half the cost of a nice sliding compound miter saw...
Re: Cross cut sled
Bought the plywood for the base today. Mail brought me a SS miter bar, Incra flip stop and a Rockler T Trak for the top of the fence. Ready to rock and roll and make sawdust tomorrow. Cold and rainy here. Not this old timers golf weather. The wife is in her quilt room making quilts and I will be in the shop. We are both doing our happy things. Does it get any better?
Re: Cross cut sled
If anyone is interested, you can find the manual for the SS cross cut sled (pdf download #845298) and the auxiliary table (pff#845309) on the main web site under manuals and information.
Re: Cross cut sled
Just waiting to hear how you intend to mount the "fence" so that the angle can be changed.
The miter track is 47/64" wide. How wide is the new miter rail? The slop that you find in this measurement defines the maximum degree of accuracy you can expect from your new sled.
Re: Cross cut sled
That 1/64" over 12" of miter bar engagement with the slot results in a angle deviation of 0.075 degrees.
The measured slop determined above will be much much less.
Therefore IMO bar/slot slop has a minimal effect.
Am I missing something???
