Cross cut sled
Re: Cross cut sled
JPG wrote: Fri Jan 26, 2024 9:15 am That 1/64" over 12" of miter bar engagement with the slot results in a angle deviation of 0.075 degrees.
The measured slop determined above will be much much less.
Therefore IMO bar/slot slop has a minimal effect.
Am I missing something???
Obviously!
I suggest that if this thought process is to continue it must first be determined "what level of deviation is to be tolerated".
How accurate is accurate?
Re: Cross cut sled
My point exactly. Minuscule does not matter.
oso2you
Re: Cross cut sled
Post by oso2you »
Dusty,
I said previously that I thought trying to do angles would create too much room for error. However, both SS and Rockler sleds have a movable fence for angles so It obviously can be done. How they do it and how it works re:accuracy I don't know. I am using a SS miter bar so there won't be any "slop".
Don
SS 520, SS band saw. Grizzly cabinet saw, jointer, drill press,14" bandsaw, belt/disc sander. Delta 13" planer. Hitachi router in router table. Old Craftsman radial arm saw.
Re: Cross cut sled
oso2you wrote: Fri Jan 26, 2024 5:44 pm Dusty,
Don
UNFORTUNATELY there will be some slop with the SS Miter Bar in the Shopsmith Miter Track(s). That will not be the nice snug fit that you might expect.
edflorence
Re: Cross cut sled
Post by edflorence »
As I recall, the SS literature instructs that as the sled is pushed forward it should also be gently pushed laterally towards the side of the miter slot closest to the blade. If this is done consistently, it should eliminate the effects of any "slot slop."
Idaho Panhandle
Re: Cross cut sled
edflorence wrote: Sat Jan 27, 2024 12:49 pm As I recall, the SS literature instructs that as the sled is pushed forward it should also be gently pushed laterally towards the side of the miter slot closest to the blade. If this is done consistently, it should eliminate the effects of any "slot slop."
Yes. That maneuver does compensate for the loose fit in the miter slot (if I don't forget).
I put on a snug fitting wooden runner to ride in the other miter slot to eliminate the slop. Then, later, I built my own sled with Incra adjustable miter bars.
