Oh, I’m working on the Forward/Stop/Reverse switch at the moment. Though I think the bearings in the motor could use a replacement. I’ll post a video here when I have a chance to get y’all’s opinion on that. I could be overthinking that one.
I carefully pulled the cover off the switch and was able to clean everything up in there. I used some adjustable pliers to carefully push the male spade connectors out of the plastic housing. I was able to get the connectors back in snugly enough but the cover took a bit of a beating. If I have to go back in there in the future I’ll probably need to use some kind of adhesive, but for now it’s good to go.
I decided to use some PTFE “dry lube” as my lubricating agent. There was a fair amount of fine sawdust caked in there that was causing the friction so I was concerned anything else would be a bad idea. Currently it switches quite smoothly!
Mark VII Motor Hums in Reverse
- Silver Member
Re: Mark VII Motor Hums in Reverse
Nice, I will keep in mind the ptfe dry lube. Good tip. Very complicated switch, glad you were able to repair yours.
Atlas 7B Metal Shaper
- Bronze Member
I’ve got the same AO Smith motor in mine. I’m replacing the bearings as well. I’m using a Timken 6203-zz as a cross for the hoover 77203 that were in it. I’m waiting on a new centrifugal switch actuator though that i butterfingered and broke the plastic spool piece off of. A Torq #C-2097 synchrosnap looks to match up nicely for these AO Smith motors. They also look to have the stationary switches available for these motors as well.
